What clutch?
I have a 2000 trans am WS6, mainly stock for now but plan on full boltons this winter. What clutches are there that keep the stock pedal feel and last for a good while? I was thinking either a SPEC stage 2, or a Ram HDX clutch. I plan on changin the slave to an 01-02 and puttin in a new master as well. any feedback is helpful
thanks,
michael
thanks,
michael
It's mainly gonna be street. Its my daily driver and if I went to any other gear than stock it'd be a 3.73 gear. I'm goin full bolt-on's for now, i'd want the clutch to hold up to 425+ tq tho, and near-stock engagement would be great. im gonna be buyin the clutch this weekend or the beginning of next week so i can install it next weekend. all quick responses are helpful, thanks
michael
michael
If its gonna simply be a blot on car, thats raced on the weekends (and not even every weekend) I'd go with the LS7 setup.....should hold the power no problem, and a bit easier pedal feel in a daily driver than most
-Will
-Will
i was thinking about the ls7 clutch but do you also have to use the ls2 flywheel or whatever? or some kind of (i want to say shim because i cant think of the name extension or something) to make it work on my car? I was just gonna resurface my flywheel if possible to save on some much needed cash
unless i'll be needing a new flywheel anytime soon, miles=95,000 as far as i know its all stock.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
