How much power can 5th gear hold?
I was thinking that with my set up, I will probally be maxed out in 4th gear before the end of the quarter mile mark. How much power will a stock Viper trans in 5th?? I want to keep mt 3:42s ( I know 3:08s would be better for DR) so I can still use 6th on the freeway.
Thanks Ron
Thanks Ron
10 Second Moderator
5th will hold everything 1st thru 4th will, but why??? The overdrive will sap alot of horsepower. I tried a chassie dyno pull in 5th and it killed my numbers. You want to stay in 4th. Try raising the limiter some in 4th so you dont go on the limiter till at least the first MPH trap cone... Unless your motor is stock and your running 22inch tall tires.
Thanks -Ron
