normal?
Old Nov 21, 2007 | 01:49 AM
FrYd-RyS's Avatar
Default normal?
is it normal for there to be some weird noises and stuff right after u got ur tranny rebuilt with
carbon fiber syncros
iron shift forks
billet key ways and new z06 clutch?
and all bearings and seals replaced
such as a spinning noise in neutral when the clutch is out
Old Nov 22, 2007 | 02:33 PM
wrencher's Avatar
wrencher
No it is not, does it goes away with the pedal depressed?
Then that would suggest that the throw out bearing/pilot bearing could be at fault.
Old Nov 22, 2007 | 04:53 PM
FrYd-RyS's Avatar
ya it does go away when i push the peddle in. i called the guy and he said it was all replaced and it was normal for the first couple hundred miles and to call him if it didnt stop
