What Short Stick?
the shorter the lever, the closer the force applied to the fulcrum, the more force needs to be applied to move the lever. The longer the lever, the further the force is applied from the fulcrum, the less force needs to be applied to move the same mass.
When shifting a car with a lot of power, and trying to do it fast and efficiently at the track, a short stick is a liability. When power is going through the trany, the syncro's tend to bind, this means that more force has to be applied during the shift to move the syncro. If you are moving it with a longer lever [standard stick] you need to apply less force to it than if you are moving it with a shorter stick. That means that with the stock pro 5.0 handle you can shift faster because less force needs to be applied.
I have a good example; A friend of mine had a 427 built for his SS. He had a pro 5.0 with a Lous Short Stick. We had a rental day and he missed 3rd gear about 80% of the time. He asked me what was wrong, I told him to get the stock stick back on it. He did, the next week we went to the track, he hit 3rd 100% of the time.
I think when it comes to short sticks for shifters is a simple choice, looks or performance. Which matters most to you?
-Joel
The biggest difference when going from the stock stick to an aftermarket isnt the length of it IMO, it's the rigidity of it. The stock one has the rubber isolator bushing and feels like your shifting with a rubber broom handle. The shifts are far from precise.
The other ones are solid mounted to the shifter, which creates the notchier feel and vibrations felt/heard. There's nothing there to absorb these sounds and feelings anymore. Now you have a rigid connection from shifter stick, to shifter, to transmission.
i've got the Pro5.0/LSS, and i've never missed a shift when i've powershifted it....the only time i ever miss anything is when i'm driving normally and not really paying attention to what i'm doing, and release the clutch a split second too soon, before it's fully in gear.
but that happened on occasion with the stock shifter, too.
i just can't stand feeling like i'm shifting a big rig with that stupid, tall-*** stock-length shifter stick
