97 & 98 trans difference?
Old Jan 7, 2008 | 04:44 PM
r.serio's Avatar
Default 97 & 98 trans difference?
Are all T-56's the same from 93-02? A guy at work said they are, I said not.
TIA
Ron
Old Jan 7, 2008 | 04:48 PM
linegtdt52's Avatar
Default trans
bellhousing is different
Old Jan 7, 2008 | 05:04 PM
ls1 joe's Avatar
The LT1 uses a clutch fork, different bellhousing, input shaft and different front plate.
The LS1 uses a completely different front plate, input shaft and bellhousing.
Amber
Old Jan 7, 2008 | 05:19 PM
r.serio's Avatar
But the trans themself are the same?
Old Jan 7, 2008 | 05:26 PM
ls1 joe's Avatar
The internals are yes.
Amber
Old Jan 7, 2008 | 05:35 PM
r.serio's Avatar
I guess I should have word it this way: If I take out the trans from my 97 SS can I bolt it to the 98 Formula bellhousing?
Are the trans & bellhousing one piece?
Old Jan 7, 2008 | 06:34 PM
jmd's Avatar
jmd
You'd need to swap it to a 98-02 input shaft and front case plate, and to check endplay at that point.
Six or seven of the trans to bellhousing bolts line up fine. But even if you did that (please don't) you'd have the wrong length input shaft.
Old Jan 7, 2008 | 06:46 PM
ls1 joe's Avatar
Exactly. Also the LS1 transmission uses a slave cylinder bolted to the transmission not the bellhousing. No you can't just bolt it up.
Amber
Old Jan 7, 2008 | 08:05 PM
r.serio's Avatar
So I was right & I get a free lunch tomorrow at work. Thanks everyone
Old Jan 8, 2008 | 06:34 PM
thesource's Avatar
They are the same (as noted above) except for the 93 model which has a different gear ratio .
Old Jan 9, 2008 | 08:35 AM
minesfaster's Avatar
Ls1 = push style clutch
Lt1= pull style clutch
Along with many other thing's that are different !
