problems with new mcleod MC!!
------xxxxxxx----0000
the lines being pressure, the x's being engagment, and the 0's being slack. and believe me ive bled and bled the system and tried every way to do it.
to get all the air out.
was the rod end bottomed out when you bled it?
drop the eye bolt a little lower than the pedal the
next time you bleed it, then re-adjust it to the way it was and see how it is.
then if you still don`t like it, extend the rod a little past
the pedal.
the pedal down to it (max up)
this way plunger is all the way up
when you start to bleed.
i`m not sure if i am explaining this well,
but it would be best to bench bleed th master
if it is possible.
taking the plunger to it`s max up
and max down is best.
---xxxxxx-0000000
i dont know what to do. im eventually going to let it gravity bleed and keep an eye on the fluid while doing so. Also, while gravity bleeding do i need to keep the pedal held to the floor, or do i just need to leave it up?
