My 6th gear only has 2 clicks to engage instead of 3
Old 07-06-2003 | 12:47 PM
Scalpel's Avatar
Default My 6th gear only has 2 clicks to engage instead of 3
Normally, when shifting into any gear on the 98+ T-56 trannies you encounter 3 nudges/clicks to engage the car into gear. This is felt in every gear if you do it slowly you can feel the 3. Well, 1-5 have the 3 nudges/clicks but 6th gear only has 2. It has been this way since I bought the car from Tony. I have tested out 5 other LS1 T-56 powered cars and they all have the 3 clicks to engagement in every gear, including 6th. My question is, "Is there something that wasn't installed in this rebuilt tranny?"
Also, sometimes when I shift it into 6th, the full 2 clicks, I let on the clutch and nothing, it's not engaged. I'll have to re-engage the shifter to seat it again and then it'll work. I know all the gears require these 3 clicks/nudges to engage the gear properly.
Damn tranny.
Old 07-06-2003 | 12:49 PM
DERTY's Avatar
The Bull
Default Re: My 6th gear only has 2 clicks to engage instead of 3
Does it have an after market shifter with the adjusting nuts? If so you may want to see if that's holding it back. My B&M was the same way until I backed those out.
Old 07-06-2003 | 07:45 PM
Scalpel's Avatar
It has a Pro 5.0 with NO bump stops in it, the stops are removed.
Old 07-07-2003 | 06:55 PM
14u2nv's Avatar
How come Tony didn't have any of these problems? Just kidding! If I were you I would have the stops re-installed in the shifter. Without the stops, you can damage the internal stops.
Old 07-07-2003 | 06:59 PM
Scalpel's Avatar
I'll re-install the stops however I still don't know why the engagement of 6th gear is like this.
