Advice on pulling T-56
If you don't have jackstands, another method would be to use a car hauler and its ramps, pull the car up onto the rear of the trailer so that just its front wheels are on it (trailer attached to a truck of course). Don't forget your wheel chocks. Been there, done that <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
If you got a heated garage to do it i wouldn't mind helping out, i've done 3 clutch installs on my car so far.
Here's a couple of hints.
1) Drain the tranny first. Once the driveshaft is out and you unbolt the tranny mount the tranmission fluid will flow out the output shaft if it's full.
2) You'll need a REALLY long extention as Tony mentioned. The swival can be a bear to get lined up so what I do is put a little electical tape around the joint. Just 2 or 3 loops should do. It keeps the swival from being too loose and you can actually bend it to the angle you want before putting it up in there. There are two bolts and they are very hard to see. I tend to have a buddy inside the car holding the ratchet w/ 4' ext through the shifter hole. Then I feel for the top bolts and put the extension over top. My buddy is there to make sure it doesn't move. Then I can just slide back and ratchet her off. It's pretty easy once you've done it the first time.
3) If you going jethro style, as I do, you'll want to jack the entire car up as high as possible and try and keep it level. Once the bolts are out, the tranny just doesn't fall. The input shaft is still inside the engine. So you have to wiggle it out and it's helpful if the car is level and you have as much clearance as possible.
4) Jethro style will also require you to have two hyd. jacks w/wheels to support the front and back of the tranny as your trying to wiggle it out and wiggle it back in later.
5) Once it's time to reinstall. Be sure to have white lithium grease for the input shaft and RTV Red silicone gasket maker for the shifter and tranny drain plug.
6) One last thing, the clutch hydrolic line can be a little tricky to get off. You have to slide the sleeve towards the tranny with two flathead screwdrivers(least that's what I used). It should make a tiny little snapping sound once you got it and it slide right out without letting air into the line.
That's all I can think of. The other guys covered the rest. Good luck.
Mike B.
you don't need a lift or heated garage, as long as you have the right tools you'll be fine. I don't know what the "jethro" style is but a floor jack or two helps. definitely get a 3 foot extension and swivel sockets, have some 1/2" to 3/8" and 3/8" to 1/2" adapters on hand with an assortment of extensions and universal joints. besides that just some sockets and you'll figure it out. when putting everything back together just remember to put the torque arm on before the driveshaft, I wasted time doing that.
[IMG]http://i55.tinypic.com/15gbhoj.jpg[IMG]
And like others...here's my "shop" haha.
Its easier than you think... This was the first time I removed a trans from a car by itself...without pulling the motor at the same time. And even with my custom exhaust in the way, it was a piece of cake. I couldnt get my car up high enough to do the chest method, so the little cart worked great.
J.
It is a big pricey at $80...but you can get them on sale usually, and they're pretty worth it.
J.
J.
