How can I increase shifting speed?
#41
I haven't messed with my stock tables, but which one are you talking about? Are the values left over from your automatic days? One of my stock tables, Airflow Decay vs. Speed, is zeroed out above 12 MPH. Is that what you see? For Airflow Decay Delay vs. Speed, it's all at 63.999 seconds above 12 MPH. The other table, Airflow vs. RPM vs. Speed, only has zero values at 0 MPH from 400 to 1600 RPM. I can send you each of my tables if you like.
If yours it's zeroed out above 12 MPH it's not stock
My program is 100% M6 with stock Throttle Cracker values, no residuals of the old A4 program.
When I replaced the clutch included slave cylinder I kept the old master cylinder. I have a new one here and I'll install it in 1-2 weeks, hopefully that will solve the problem! (the actual master cylinder came with the tranny swap kit and it's probably from a 99 car = 9 years old...).
#43
#44
The installed master is modified (adjustable + drill mod) and is 9 years old (hehe!)
The new one is still in my garage... not adjustable and not drilled.
I'm not sure if I'll modify it.
A strange thing: when I apply the cluth pedal several times (maybe just 1/2 of the movement) it gets harder to move. There is a friction somewhere.
I can't imagine that it's the clutch. The slave? The master? THis becomes worse when the engine (and all the rest) is hot.
#45
Well, you know, that's sounding a lot like there's either air or water in the line. Did you get a chance to flush the hydraulics again, or are you going to wait until the new MC goes in?
#48
Not being married would make that way much easier
By the way: I made a scan of my shifting: from 100% TPS, shift and next 100% TPS it takes 1.0 seconds. Every shift takes the same time.
Same for 1/2 throttle shifts (50% to 50%).
I'm sure it shuldn't take more than 0.5 sec...
Once you sent me a scan of your shifting: it was between 440 and 640 ms!!! Half than my time...
#49
By the way, you officially qualify as the hardest working guy in Switzerland.
#50
Today I replaced the master cylinder and (obvioulsy) bleeded the lines.
It shifts better, much better!
But to be honest I'm not sure that the new master cylinder did the miracle...
The older cylinder isn't damaged and (inside) it looks fine.
The older cylinder was adjustable and the pedal was about 1" higher than the brake pedal.
Now, with the new master (not adjustable) the pedal is as high as the brake pedal and the movement is now shorter than before (1" shorter).
The clutch is disengaging correctly and somehow it shifts faster... maybe because it takes less time to push the clutch pedal?
The next move will be to fll Mobil Synthetic ATF... I''ll post the results.
By the way: I bleeded the hydraulics with pressure, the best way so far
The new master isn't drilled and I honestly I can feel no difference.
