Tips for hillbilly tranny removal...
Old 02-13-2008, 10:07 PM
  #41
hndakilr's Avatar
26 spline if im not mistaken
dont take it all at once, just about everyone takes the trans off first.
you will spend alot more time trying to get it off in one piece than you will taking it off all at once (if you can)
Old 02-14-2008, 03:58 AM
  #42
nighthawk15's Avatar
If it is possible, I sure as heck don't see how. Especially that bolt up in the 10 o' clock position
Old 02-16-2008, 01:36 PM
  #43
Black8Banger's Avatar
If you are a skinny guy, you can snake your arm to the top bolt on the bellhousing and attempt to guide the socket. Why waste your time, just unbolt the tranny from the bellhousing!
Old 02-19-2008, 05:13 PM
  #44
ErikElvis's Avatar
ok fellas need help quick. Where the hell is the clutch line I need to disconnect before dropping the tranny?
Old 02-19-2008, 05:46 PM
  #45
ErikElvis's Avatar
nevermind I think I got it. Guess I have to pop the tranny off the bell housing before I can get to the slave. Kinda just removing things until I get stuck instead of learning ahead of time.
Quick Reply: Tips for hillbilly tranny removal...
