m6 groans
Old 02-22-2003 | 01:00 AM
99pewterTA's Avatar
Default m6 groans
Today i was cruising and my car didn't want to shift into gears. Then i took off pretty hard and and it got really hard to shift into gears then <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> it starting shifting good but groans pretty bad between shifts. It also was groaning while i was stopped with my foot on the clutch so I can't figure it out. Was thinking synchros becuase clutch doesn't slip and works fine.
Old 02-23-2003 | 02:32 PM
01 ls1 z28 DA BRONX's Avatar
Default Re: m6 groans
if its making nosies when your stopped and your foot down on the clutch pedal.. its most likey your pilot bearing/bushing..
check your fluid level.. pull the drain plug out and stick your finger in the hole.. if the fluid is right at that level your good.. if not.. add fluid.
hope this helps..
