Slave cylinder strikes again?
Asking this to help out a friend, plus I was supposed to buy the car this Friday! Its an 02. She had trouble getting it in and out of gear, got progressively worse as she tried to get it home. This all happened in about a 3 hour time span, it hasn't been showing problems. I don't think its the clutch because she babies the car and doesn't drag it or drive it very hard. I drove the car 2 weeks ago and everything felt fine to me. Apparently once in gear it doesn't grind but it does grind when going into gear, like something isn't engaging or moving out of the way inside of the tranny. Its at the transmission shop right now & we should get their "expert" opinion in the morning, which will probably be to rebuild & replace everything. Sounds like it needs a new slave &/or master cylinder and a good fluid flush?
