Lookin for best T56 Clutch under $500
I had a RAM910 with the VDS Pressure plate (like the links posted) in my 440rwhp setup. It was a heavy pedal effort setup; however never missed a beat. It lasted about 25K hard miles. For the money it was great. In severe stop/go traffic it tired my leg out.... but tolerable. It was rated at 600hp (flywheel).
I would think about running an aluminum flywheel if you have the $$$. It will rev soo much faster. The Textralia 0Z700 and Exo-Skel are nice.... but $'s.
An LS7 clutch will handle about 500rwhp and drive like stock. I purchased one brand new from Scoggin Dickey for $269 (clutch disc and PP). I'm going to run a Fidanza alum flywheel as I loved how fast it revs with one. I have a heads/cam LS1 making just under 500rwhp I'm building up. (TFS 215's, FAST 90, 240/244 cam)
IMO I wouldn't run a Spec clutch due to the many stories of them failing and actually exploding. Happened to a number of Vette guys. Do a search on here about the horror stories with them. Some work great.... others don't. I've heard from many saying they are wonderful clutches.... but not everyone thinks so.
centerforce 12in is the best out or all i have tried mcleod, spec 3 and 4.super cheap too!
p.s. alum flywheel rapps so much faster than stock and my best times are on an alum one. my wheelie was a steel though
I had 40,000 hard miles on a Ram Powergrip HD...I loved that clutch. Heave pedal pressure, a little chatter, with a stock flywheel. I think it would have lasted longer if the flywheel wasn't trashed.
I now have a Centerforce DFX. Light pedal pressure, not much chatter, with a fidanza aluminum flywheel. It has held for 9k even harder miles on drag radials, and just put in a 9" with a steel driveshaft. Also, 3rd gear just took a **** after 120,000 miles lol.
