clutch issues
this setup did awesome for a while, but now the clutch slips in high gear and low rpm only. over time its started to work itself into the lower gears. but i just did the clutch test where you go 30 mph and put it in sixth then put it to the floor. and the first and second time no slippage but the second two times it slipped like hell.
when putting trans fluid in my trans i think that i may have put a little much because i didnt use the fill plug. maybe it fluid shooting out of a blown seal, maybe. or maybe the master isnt capable of pulling the fluid back out of the slave after sending it there. i dont know what caused this to happen, but i do know that now i have got to replace a clutch because of it.
ANY THOUGHTS???? ANY HELP WOULD BE FANTASTIC.
If you had transmission fluid spraying around, you'd find some nice transmission fluid puddles underneath the car where you park. The clutch has a vent hole for fluid to come out during a bleed.
I would say you killed the clutch. If the hydraulics weren't bled properly or the slave shimmed according to the spec clutch's required shim, then you could have been draggin the clutch during shifts which could have caused excess wear on the clutch and eventually lead to it's failing to hold anymore.
