T56 problem after swap!
Hi,i've recently did an A4 to t56 swap & it went very well.
the problem is when i shift into reverse the shifter pops back out,i've even tried to hold it there but it pushes back out & when i shift from 1'st to second i hear a kshhhhh grind sound even at low & high speed.
could this be a clutch or synchros problem??
Any help appreciated.
Oh and "you bent a fork" translates to "I am diagnosing your trans based upon reading things on the internet."
Get the trans. out, the offset shift lever removed & yank the tailhousing. You'll pretty quickly be able to see if you still have a good (unused / worn) side left on your reverse synchro and whether the reverse gear has the teeth ground down.
Thanx for the help.
