need t-56 help IMMEDIATELY!
Old Mar 21, 2003 | 04:34 PM
lucky_topher's Avatar
Default need t-56 help IMMEDIATELY!
i've got synchros on my LS1 in the M6 t-56 that went out right at about 70k miles... it looks like the warranty company is goign to try to NOT cover this... i need any documentation that you can provide stating this is something that has been & should be covered by a warranty!
Old Mar 21, 2003 | 10:49 PM
MIGHTYMOUSE's Avatar
Default Re: need t-56 help IMMEDIATELY!
do you have an extended warranty?
tell them if they dont fix it you will be happy to continue using the transmission until you break someting more expensive that IS covered under warranty.. worked for me ;D
Old Mar 22, 2003 | 01:00 PM
they're trying to blame it on my B&M shifter saying either the aftermarket shifter or improper shifting was the cause of this... quote is $27xx ....
Old Mar 22, 2003 | 02:51 PM
WMSuperSport's Avatar
Sounds like a classic case of good ole GM Customer Service!
Right when I bought my car, I was soon screwed out of my warranty, because there is a 30 day limit to return all the paperwork. Oh well, so then I just started all the modifications. Think of it like that.
