replace pilot bearing?
I used a generic pilot bearing remover and a slide hammer.
If it doesn't come out easily just use a hammer and a chisel to cut the bearing in half. Just make sure the chisel is smaller than the bearing diameter so you dont make contact with the crankshaft.
I just did mine on a 2002 and it was not a roller bearing. This should be replaced everytime you do the job. Mine came apart and almost messed up my input shaft. The input seal started leaking and ruined my clutch. I would say put in a new roller style bearing while you are there.
Just break it so it looses all its strength and then clean out the back of the crankshaft so no metal is left behind.
Attached are a few pics of the tool I used.
Chris
You'll knock a plug into the oil pan on these engines. I rented a blind hole puller with a slide hammer from Autozone to get my pilot bearing out. Took a few times but I eventually removed it.
