need a measurement on a ls1 street twin clutch assembly? HELP!
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
does anyone have one of these that they could measure? i don't think it matters but i do have an aluminum flywheel.
all i need to know is the distance from the back of the flywheel to the tip of one of the fingers on the borg and beck pressure plate. should be in the 3.2" to 3.5xx" range. I measured one in a friends car, but it is hard to do while it is in the car.
oh also i need the finger measured on the crown of it not the backside which would be the side closest to the flywheel/engine.
hmmm, i just measured my friends on friday, found it to be 2.205" from the face of the mcleod b/h. thanks for the response! but i need the dimension from the face of the crank. due to mine being an lt1 car.
thanks
taner
thanks
taner
