T56 Rebuild "how to" write up
Old Feb 26, 2012 | 08:45 PM
  #161
94camaroz28lt1's Avatar
Originally Posted by Brians602
Shifts are rough (in all gears) when the car is moving only. With the engine off it does slide freely into every gear. I didnt jack it up and start it to see if the wheels turn but i tried puting it in & out of gear with the engine running while holding the clutch. The idea being if it wasnt sliding freely into gear then the clutch is not releasing.
i did check endplay and shim the mainshaft to whatever tremec recommends in their service manual i cant remeber ATM. But how would it being shimmed too tightly cause hard shifts?
I just pulled the trans. again to double check the air gap between the slave and pressure plate, and its almost zero.
i have the trans. out still so ill get on checking the flywheel and pressure plate although they seemed fine before.
The weird thing is when i bled the slave it initially shifted fine but the next day it was back to its old ways. I have since tried bleeding the little **** but it doesnt seem to do any good.
Im wondering if the slave is bad already (i just replaced it 3 months ago) or if theres a small leak in the clutch hydraulics somewhere. I just dont know how to go about determining which it is...
Thanks for the input it is very much appreciated
The clutch master could be bad, or a leak in the system. Some clutch systems are a bitch to bleed, I'm not familiar with GTO, but sometimes they require a vacuum bleed kit.
As for the trans it's unlikely but possible, that the trans is shimmed to tight. But in theory if it is to tight the synchros may not spin on the gears and therefore "stick" cause rough shifts.
Does it shift better ounce warm? Then the case expands, and allows the synchros to spin "slip" again.
If there is two many shims and the trans is really loose, the synchro will spin to much, and not have enough force to spin the gear up to speed causing them to clash or grind. This will get worse ounce the trans heats up.
Also not to be an Asshat, but did you use ATF 3 or 4? You didn't use gear oil or synchromesh fluid did you?
No problem on the help, I hope you can get this straightened out.
The best way that I know off to separate clutch and tranny issues is to jack the rear up and start it put it in first release clutch then depress. see how long it takes to stop. if you didn't use the gas pedal, and it's just in-first it should stop within about 5-10 seconds. If it doesn't definitely seems clutch related.
You can also do the 1st to reverse test. drive forward on the ground in 1st come to a complete stop and go for reverse if it grinds the clutch isn't releasing, or there is a internal transmission problem!
Old May 22, 2012 | 08:05 PM
  #162
ls1evan's Avatar
Hi guys, I noticed that the manual does not have part numbers. Check out this document I got from my local chevy dealer. He said the pic is specific to a 2000 z28 t56.
links:
http://i1269.photobucket.com/albums/...nford/t561.jpg
http://i1269.photobucket.com/albums/...nford/t562.jpg
http://i1269.photobucket.com/albums/...nford/t563.jpg
http://i1269.photobucket.com/albums/...nford/t564.jpg
http://i1269.photobucket.com/albums/...nford/t565.jpg
http://i1269.photobucket.com/albums/...nford/t566.jpg
http://i1269.photobucket.com/albums/...nford/t567.jpg
http://i1269.photobucket.com/albums/...nford/t568.jpg
http://i1269.photobucket.com/albums/...nford/t569.jpg
http://i1269.photobucket.com/albums/...ford/t5610.jpg
http://i1269.photobucket.com/albums/...tanford/me.jpg
[edit: removed ridiculously large images]
Old May 22, 2012 | 08:28 PM
  #163
cam's Avatar
cam
Heres another link to the manual just in case
T56 Service Manual
Last edited by cam; Aug 4, 2014 at 07:32 AM. Reason: pics are gone, edited to avoid confusion.
Old May 22, 2012 | 09:20 PM
  #164
ls1evan's Avatar
Cam:
good point, I did not see that manual (damn, that thing is detailed. I've got some reading to do )
Although... I didn't see part numbers in either link so I will leave links only in case someone needs them and is too lazy to do a web search.
BTW- this is a great thread and I might not have done the rebuild myself without it! thanks LS1tech!!!
Old Sep 27, 2012 | 07:17 PM
  #165
388_stroker's Avatar
http://www.thegearbox.org/catalog/it...74/4455302.htm
I plan to rebuild my tranny next week and this manual may help... No idea how good it is yet but I'll post afterwards. I'll definitely refer to this write up as well, great job
Old Mar 2, 2013 | 11:31 PM
  #166
anthony.fatica's Avatar
I know this threads been dead for some months now, but wanted to extend a huge thanks to the OP and also to the shower curtain rod guy. Great write up and great idea! Huge help
Old Mar 10, 2013 | 04:41 AM
  #167
68Goatboy's Avatar
I had to remove the front adapter plate to make some measurements on with the quicktime scatter shield i have. it came off with little to no problem.
is there any special procedure for reattaching the adapter plate to the rest of the transmission? I tried putting it back on but after i tightened it back down the shifter didnt feel like it was engaging in all the gears.
any advice or ideas?
Old Mar 28, 2013 | 07:10 PM
  #168
mulberryriver2's Avatar
Broke open my t56 with 156,000 miles on it. Heard the horror stories about the 5/6 cluster. Crossed my fingers and said prayers but sure as **** that thing was ON there! Tried twice with heat and pullers. I applied an unimaginable amount of force, but it held it's ground. so, I connected two 6" two jaw pullers and cranked it down with the impact. I left it over night and all day at work. Come home, go straight over to it and hit it with the acetelyne torch and POW! A few more turns with the impact and a lil more heat and it came right off!
Old Mar 29, 2013 | 12:29 AM
  #169
jmd's Avatar
jmd
You could have dropped the 5-6 and R shift rails out of place. To fix:
remove the reverse light switch
Lift the 5-6 shift rail so it's claws hook over the shift interlock ring properly and the groove at the top of the claws lines up with the guide bolt that's threaded into the case.
Stick a long thin screwdriver in the reverse light opening. That will hold things up.
Then reinstall the front plate.
Old Apr 3, 2013 | 11:32 PM
  #170
Snyper's Avatar
Does anyone have the part number on the small taper bearing on the stubby end of the main shaft? Could not figure out how to remove the gears without destroying it and now I need a new one. All of the other bearings are perfect.
Old Apr 4, 2013 | 09:49 PM
  #171
I have a complete bearing set that came with my rebuild parts. I'm not replacing the bearings and need to sell the new ones. Make me a decent offer and I'll send it to you.
Old Apr 5, 2013 | 01:45 AM
  #172
jmd's Avatar
jmd
Post
https://ls1tech.com/forums/14259776-post16.html
there is the set # as well as the individual numbers.
Old Apr 6, 2013 | 07:32 PM
  #173
Snyper's Avatar
This trans build has been a nightmare. I have an MN12 and it seems as though there are a lot of different parts. Is there a PDF for an MN12?
Old Apr 6, 2013 | 11:35 PM
  #174
jmd's Avatar
jmd
It's an interesting learning curve the first time through. Next one goes easier.
Old Apr 7, 2013 | 11:51 AM
  #175
Snyper's Avatar
This is true. However I have a few left over pieces. An aluminum ring, a flat graphite washer and a rubber o Ring. The retainer is now in its correct place.
One part of concern is #108 thrust washer in this picture. I know for a fact that I did not misplace a single part and the only washer I have right there is a very thin washer (one on each side of the bearing) but its not thick like this. Any ideas? Maybe it's different on the mn12? It would be metal to metal contact but there are oil grooves on each part of the shaft.
Old Apr 7, 2013 | 01:26 PM
  #176
jmd's Avatar
jmd
108 is a countersunk washer on the double/single cone boxes.
It isn't present on the triple/double cone boxes. They instead have a thin bearing washer on each side of the 6th countershaft gear bearing and the gear has an extended tube section IIRC.
Flat washer goes on the hub of the reverse synchro under the wave spring, which is under the brass blocker ring.
There's a 40mm? rubber o-ring on top of the tapered bearing right behind 1st gear.
The ring looks like a bearing spacer; it should be obvious during assembly that a gear has roller bearing underneath it with extra room for a spacer.
Old Apr 7, 2013 | 01:53 PM
  #177
Snyper's Avatar
The rubber O ring on top of the tapered bearing is a very thin o ring. Much thinner than this one. And that aluminum spacer didn't seem to fit anywhere that I could see.
Old Apr 7, 2013 | 03:05 PM
  #178
jmd's Avatar
jmd
A picture is worth a thousand words. Measurements are priceless.
GTO box, yes?
Old Apr 7, 2013 | 03:12 PM
  #179
Snyper's Avatar
GTO box, yes?
Yes GTO box. It's an alumining ring with no taper. And the rubber gasket also seems too big to fit on any part of the shaft.
Old Apr 7, 2013 | 04:35 PM
  #180
Snyper's Avatar
These are the only two piece left that don't seem to go anywhere.
Aluminum ring
Rubber gasket
