Shifter problem
Old May 31, 2008 | 04:31 PM
95 Z28's Avatar
Default Shifter problem
In the midst of my clutch swap, managed to drop the shifter unit on the concrete floor of the shop. When I put it back in, it had a little extra play in the shifter when it's sitting in the neutral position. I can move it in any direction maybe 1/2" - 3/4" while it's sitting in the middle. It still will go back to the middle if you pull it left or right, just not with the authority it used to. Anyone have any clue what I might have fucked up when I dropped it? Maybe knocked one of the springs out of whack? It's a B&M unit.
Old May 31, 2008 | 04:34 PM
95 Z28's Avatar
BTW, after checking the floor thoroughly, I couldn't find anything that popped off. I'm going to pull it off the car tonight and check it over really closely, but if anyone has an idea let me know.
