Where do you get the DOT 5 fluid for the Cartek Clutch?
Old 04-12-2003 | 12:09 PM
Scalpel's Avatar
Default Where do you get the DOT 5 fluid for the Cartek Clutch?
I'm having the lazy clutch pedal if I take the car above 4K RPMs with the Cartek Clutch. Dave @ Cartek told me to use DOT 5 fluid in the lines to prevent this from the heat build-up. Where do I get this DOT 5 and should I flush the lines with something before hand to prevent contaminating the new DOT 5 I'll be putting in? Thanks.
Old 04-14-2003 | 12:03 PM
Slick9.5's Avatar
Default Re: Where do you get the DOT 5 fluid for the Cartek Clutch?
sorry I dont have a clue where u can get dot 5 brake fluid, but I was wondering how do you like that clutch for daily driving and for the strip?
Old 04-14-2003 | 12:30 PM
Scalpel's Avatar
It has no chatter at any time and it never slips. It works very well aside from the lazy pedal issue with the hydraulics. Dave @ Cartek told me he ships out the new Cartek Clutches w/DOT 5 now to prevent this.
Old 04-18-2003 | 02:39 AM
Spinmaster's Avatar
Check out some import shops. Some imports use Dot 5 brake fliud.
Old 04-18-2003 | 11:37 PM
Mechanicsn's Avatar
I've found the best place to reliably find DOT5 fluid is a motorcycle shop. They use DOT5 fluid in a lot of the bikes from the factory. Good luck, Kelly
Old 04-19-2003 | 10:10 PM
Classic's Avatar
Might want to check out Walmart as well. I know they carry Dot 4, and I believe they carry Dot 5 as well - but not sure.
Old 04-20-2003 | 11:02 PM
14u2nv's Avatar
BMW uses DOT 4. I have never seen DOT 5. Try Napa though. Its my understanding that the LS1 clutch hydraulics do not hold up very well with synthetic fluid.
