how do i use this slide hammer?
I used the autozone pilot puller with the slide hammer, and had to grind the jaws of the puller down a little to fit inside the bushing. Tighten up the nut, hook the hammer to it, and slide away. make sure the jaws are expanded out and the puller is super tight before you start slide hammering it
WOOOOOOOOOOOOOOOOOOA
http://www.harborfreight.com/cpi/cta...emnumber=95987
im going to pimp this item because THIS THING ROCKS!!!!!! took me 5 whacks and the pilot bearing fell out!!!
ALSO! HARBOR FREIGHT IS THE ****!!
