grinding when reved
Old Aug 4, 2008 | 10:42 AM
adio's Avatar
Default grinding when reved
i have a 94 camaro 3.4 v6 5spd its never been ragged on i have known the last 3 owners but anyways when i put it in first it goes in smoothe with no grinding or anything and it goes through all gears nicely but if i have it in first gear and rev it grinds like crazy i dunno what this may be do you guys have any suggestions?
Old Aug 4, 2008 | 10:53 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
In first gear with the clutch out, or is the clutch depressed?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Aug 4, 2008 | 11:28 AM
adio's Avatar
i have the clutch pressed down to the floor
Old Aug 4, 2008 | 01:23 PM
thesource's Avatar
Are you sure its a grinding sound and not the throw out bearing making a growling noise ?
Old Aug 4, 2008 | 01:24 PM
adio's Avatar
it makes the same sound as when you miss a gear except when you miss a gear its only for a second this does it until the rpms go back down
Old Aug 4, 2008 | 03:51 PM
adio's Avatar
well i have never let it idle back down when it does it i always take it out of gear and it quits but i can put it right back into first after that and its fine until i rev
Old Aug 4, 2008 | 05:06 PM
thesource's Avatar
Sounds like its not going all the way into gear . Turn the car off , put it into 1st gear . Start it back up and rev it in 1st gear . If it does not make the noise , you have a clutch issue .
Old Aug 5, 2008 | 08:04 AM
adio's Avatar
yeah but if wasn't in gear all the way i wouldn't be able to drive it would I?
Old Aug 5, 2008 | 08:55 AM
thesource's Avatar
No you would not be able to drive it if its not all the way into gear . If the noise is there all the time in 1st with the clutch pushed in , its not in the transmission since its not turning .
Old Aug 5, 2008 | 09:16 AM
adio's Avatar
its not there all the time just when i rev. if i pull it out of gear it quits and i can put it back in gear with no problem
Old Aug 5, 2008 | 09:39 AM
adio's Avatar
im kinda new to american cars is the t5 tranny whats in my car?
Old Aug 5, 2008 | 02:13 PM
adio's Avatar
my girlfriends uncle is a master mechanic im taking it to him today ill let you guys know what he says
Old Aug 5, 2008 | 02:53 PM
thesource's Avatar
Based on what you are describing , I'm gonna say its not going all the way into gear .
Old Aug 5, 2008 | 03:34 PM
adio's Avatar
i don't see how that is cause i drove it like 100 miles today with no issues it only does it when reved lol
Old Aug 5, 2008 | 05:11 PM
thesource's Avatar
Well then its something in the engine or clutch because there is nothing inside the transmission that will cause that unless you are not putting it all the way into gear . Did you do like I said about putting it in gear with the car off and then starting it to see if it will make the noise while revving it in 1st with the clutch pushed in ?
Old Aug 6, 2008 | 05:12 AM
adio's Avatar
ill try that today
By Brett Foote | 2026-06-04 05:00:17
