GM LS1/LS6 flywheel thickness & clean-up specs?
Old 08-08-2008, 11:10 AM
LS1-450's Avatar
Default GM LS1/LS6 flywheel thickness & clean-up specs?
How thick is the stock GM flywheel (flex plate) from the crank surface to the friction surface? How much friction material can be removed while machining (clean-up)? Thank-you.
Checked the stickies & did a search; couldn't find after reading several pages.
Quick Reply: GM LS1/LS6 flywheel thickness & clean-up specs?
