Questions on synchros. Input needed!!
Old Aug 30, 2003 | 11:26 PM
alexWS6's Avatar
Default Questions on synchros. Input needed!!
I was looking at a used 98 6 spd F-body and the salesmen told me the car was having the synchros in 5th and 6th replaced. The car has 58,000 miles. Is this normal? Does it neccesarily mean the car was shifted incorrectly and/or driven very hard? Does it seem weird that only 5th and 6th's are being replaced and not the others?
Thanks in advance for the help
Old Aug 31, 2003 | 01:10 PM
wrencher's Avatar
wrencher
Default Re: Questions on synchros. Input needed!!
The salemen can say whatever, thats prolly how much he knows about what it does need.
If it was driven hard, synchro's can be toast.
EDIT; but it is usually 2,3 &4th that get abused.
Old Aug 31, 2003 | 01:53 PM
alexWS6's Avatar
thats what I would have thought. so say all the synchros were damaged, what else is potentially damaged and in need of repair?
Old Aug 31, 2003 | 07:15 PM
wrencher's Avatar
wrencher
Shift forks are also common for damage/& or bending.
Old Aug 31, 2003 | 11:10 PM
14u2nv's Avatar
My synchro for 5th was replaced at 18,000 miles. Honestly, how can you abuse 5th & 6th gears; they are overdrives for christ's sake. MY local trans shop was told by their distributor for the new synchro(updated version, not the paper version) that 5th & 6th syncho is a bad design and will typically go bad even if rarely used. I don't know how true that is but my SS has only been to the track maybe 10 runs total and I DO NOT powershift.
Old Sep 2, 2003 | 11:00 AM
MyLS1Hauls's Avatar
If you drive the car hard/wrong, they will all wear out, but its usually 2,3,4...but 5th and 6th arent the same material as the rest and are therefore weaker. If you buy the car, make sure they will warranty the trans for at least 3k miles to be sure the put it back together correctly.
Old Sep 3, 2003 | 11:49 PM
SSEUL8R's Avatar
How can you tell if your synchros are going bad? Just takes too long to go in gear or what? grinding? what are the symptoms of bad synchros?
Old Sep 4, 2003 | 10:00 AM
MyLS1Hauls's Avatar
The gears will usually grind when the synchros are worn out.
Old Sep 4, 2003 | 10:43 AM
JRcamaroZ28's Avatar
I bought my '98 used and it only had 19K on the clock and I had to have the syncros redone under warenty. took it on my first trip and every time i'd shift from 5-6 or back down it would grind. had it warrenty rebuilt and no problems yet and i have 36k on it now
JR
