shifting problems after 9'' install
Old Sep 3, 2003 | 10:06 PM
Classic's Avatar
Default shifting problems after 9'' install
Ever since I put the ford 9'' under my car, my tranny just hasn't been quite right. The problem is that when shifting easy into a gear you can really feel the engagement - like gear on gear, with a little "clunk" sound to it. Kind of hard to explain exactly - but a real solid metal feel instead of the "typical" feel I guess. I do have a pro5.0 so I know I am feeling a lot more than the stock shifter, but it was not like this pre-9''. Just looking for some thoughts/suggestions. Its not the end of the world, but I'd like to know whats going on.
Old Sep 4, 2003 | 03:51 AM
67pete's Avatar
Default Re: shifteing problems after 9'' install
Check the alignment angles between the rear and the trans,you could be preloading the trans with too much delta.
Old Sep 4, 2003 | 06:41 AM
Fireball's Avatar
when I put my 9" in, my driveshaft was a tad too long. It would go in but wouldn't have hardly endplay. I tore up 4th gear twice because of this. Once I put in a shorter driveshaft and haven't had this problem since
Old Sep 4, 2003 | 08:22 AM
LOnSLO's Avatar
I had the same feeling when I put that rear in my car. I got used to it, and never noticed it while driving normally. I would recheck the shaft length though as Fireball mentioned.
