Six speed Inc!
Old Sep 5, 2008 | 11:23 PM
Jrp1978's Avatar
Default Six speed Inc!
Amber I am hoping you are out there...
I finally got a chance to drag race my car tonight went pretty well up until last pass . I noticed a super charger sound like whinning coming from the shifter. 1 2 3 and 4th bad whinning 5 you care barley hear it and 6th gear goes away. But also in between shifts you can here its bad ? This is the same tranny got from you last winter just put 3210 on it . First time at the track ............. Any thoughts
Old Sep 6, 2008 | 10:48 AM
Jrp1978's Avatar
Default Ok anyone ???????????
Anyone had this problem ???????????????????????????
Old Sep 6, 2008 | 11:51 AM
85MikeTPI's Avatar
Do you notice it in Reverse? Did anything happen during the drag run just prior to you hearing the noise? Does the fluid look burnt?
Could be a bearing going bad on the extension shaft (5/6/R) that is free floating in 1-4, but has some tension on it in 5/6 ?
Do you have to go into 5th on the drag strip? The extension shaft is a weak link on the non-viper T56s..
Old Sep 6, 2008 | 03:14 PM
Jrp1978's Avatar
Default ok
No it happen and drag strip and its just 1 2 3 and its gotten alitte better with just driving ? Thetranny is a m12 built by six speed inc. The told me it was good to 700 hp 700 trq and i am only make 500ish . Got a textralia clutch new slave new mcload big line and adj master cylinder. I made last past last night ohhhhhhhh its 1/8th mile i rapp 3rd out to about 6200 at about 96 mph in the 1/8th
Old Sep 6, 2008 | 03:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Do you have phone service? I only ask because it should be the first thing you'd do in a situation like this instead of posting a thread on the internet.
Yeah...I know, I know. I'm a dick. But do you really expect prompt service in a public forum? Every time I've called Amber, she's been more than helpful.
Old Sep 6, 2008 | 03:42 PM
Jrp1978's Avatar
Default I know
I know Amber rocks ......... yeah i tried calling and not bashing her trans no way Amber is good peoples ..... That transaction i had with them and customer serivice was awsome . She didnt answer and I just thought the fellas online could drop a few ideas in the mean time!
Old Sep 6, 2008 | 04:10 PM
the_merv's Avatar
Veteran: Air Force
How much oil do you have in it..when it gets low that tends to start symptoms like that..
Old Sep 6, 2008 | 08:26 PM
Jrp1978's Avatar
Default full
I stopped and checked that first thing at the track!
Old Sep 6, 2008 | 09:39 PM
thesource's Avatar
A noise from lack oil would get louder as the speeds increased and would go away in 4th gear unless it was the output shaft bearing (which I highly doubt) . If the noise is there with the clutch pushed in , its probably something in the clutch area or the pilot bearing . Do you hear anything when the car is running but in neutral ?
Old Sep 7, 2008 | 11:07 AM
Jrp1978's Avatar
Default No
Only time i hear anything is if its in gear ... Its there in every gear just not as loud. ALSO WHEN YOU SLOW DOWN UNDER A LOAD AND IT STARTS TO BUCK BERFORE I CHANGE GEARS IT REALLY NOTICABLE BUT ITS ON CONSISTANT WITH THE BUCKING . BUT IF I PRESS IN CLUTCH IS ALL GONE ... AT ANYSPEED AND ANYGEAR
Old Sep 7, 2008 | 11:13 AM
ls1 joe's Avatar
In think you are hearing the bronze pads. Especially since 5/6 it isn't there. You could also be hearing clutch noise. The bucking isn't tranny related but clutch related. I would change the transmission fluid and use REDLINE D4. It is a little thicker and helps with the pad noise from what we have seen.
Call me monday and we can talk more.
Thanks,
Amber
Old Sep 7, 2008 | 11:21 AM
ls1 joe's Avatar
I have to agree with the source on this one. Pilot bearing would be the first thing to check. The other thing I would do today is take a look at the fluid. Don't be alarmed if you see a little bronze in the fluid as that is just break in on the pads. You should use 4 quarts. It could be throwout bearing also. Bronze pads would do exactly what you describe and will get better with more break in.
How does it drive? Go into gear fine? If so it is unlikely transmission related.
Thanks,
Amber
Old Sep 7, 2008 | 07:19 PM
Jrp1978's Avatar
Default Hey Amber!
First of all Amber I hope didnt mad because i posted on here before talking to ya ...... Just need something to do this weekend thought the guys would have some insight on it..... If i cluth in it wont make a sound . It goes into gear fine reverse is sometimes a pain in the ***. And once in a blue moon 3rd grinds just a touch before going in ...... I will stick some good fluid in it and go from there .....
Its just a really loud almost alternator sounding wind that you can here at the shifter If i had my hand on it and was changing gears you can feel when it doing it along with here it . It does make the sound when shifting in to 5th and 6th but i think since the rpm is low you just cant hear it aswell.
Old Sep 8, 2008 | 09:49 AM
ls1 joe's Avatar
Of course I am not mad. It was the weekend. You know I am not here on the weekends We have to go racing Call me and we can talk about the noise a little more.
Amber
Old Sep 8, 2008 | 11:08 PM
Jrp1978's Avatar
Default amber
you are a very busy lady !!!!!!!!!! called 7 times today ended up leavn a message lol! try tommorow
