Lou's Short Stick
Old 09-07-2003, 07:12 PM
Tack25's Avatar
Default Lou's Short Stick
How much would Lou's Short Stick help? If you install that on the stock Hurst shifter then can you take it off later and put it on a Pro 5.0? Thanks in advance!
Old 09-07-2003, 08:37 PM
rnr27band1's Avatar
Default Re: Lou's Short Stick
It made a bigg difference on my car, one of my fav mods
Old 09-08-2003, 05:21 PM
PongoX11's Avatar
Made a huge difference on my factory hurst--along with the MBA **** its a crazy short throw
BTW, I *think* sticks for the Pro 5.0 and the Hurst are different, but I think Lou's will switch them out for you
Old 09-08-2003, 06:00 PM
ss rally red's Avatar
I you put a LSS on a factory Hurst shifter you may not want/need a 5.0
Old 09-08-2003, 10:14 PM
BLKWS6's Avatar
where do you get one of these?
Old 09-08-2003, 10:51 PM
PongoX11's Avatar
From over there ---------------->
http://www.afterthoughtsauto.com/
Old 09-09-2003, 12:40 AM
Turo's Avatar
i went with jarrod's short stick instead, pretty much the same thing but half the price ($25 shipped to my house)
Old 09-09-2003, 01:47 AM
deznuttzz28's Avatar
first time going to the track, i have the stock hurst and mis-shifted 2 times. my buddy told me about lou short stick the mis-shifting is gone... i think that the lss works as good as the Pro 5.0, got it from lmperformace.com.
Old 09-09-2003, 03:50 PM
Tack25's Avatar
Does it still have a big effect if you have installed the skip shift eliminator?
Old 09-09-2003, 06:04 PM
jrp
SN95 Director
jrp's Avatar
i have a pro 5.0 w/lss i bought from afterthoughts(great service btw ). shifting is way shorted and alot crisper and firmer. i also !cags.
with the pro 5.0 w/lss and !cags its definately increased my driving experience 10 fold
Old 09-09-2003, 07:43 PM
14u2nv's Avatar
I am going to try a Short stick before I buy a Pro 5.0 shifter. For those that have tried both the LSS and JSS...which is better?
Old 09-09-2003, 07:54 PM
Turo's Avatar
here's a comparson between the 2, JSS and LSS:
http://www.ls1.com/forums/showthread...hreadid=348398
Old 09-10-2003, 09:07 AM
skippytheloon's Avatar
so...does Lou's stick angle toward or away? Common sense would say toward the driver. but I wanted to double check before I bought one.
Putting 4.11's in your car really makes the sloppy shifting a BIG problem! *shift**shift**shift**shift*... "arrgh!! Wish I had gotten the stick before the gears!"
Old 09-12-2003, 12:59 AM
jrp
SN95 Director
jrp's Avatar
it goes toward the driver if you install it correctly
Old 09-13-2003, 05:31 AM
1BadAzzWS6's Avatar
I love the LSS and Pro 5.0 combo...makes a world of difference and feels much more comfortable and fun to drive. Definately worth the money I spent. I bought the combo from afterthoughtsauto. they had it shipped to me fairly quickly.
Old 09-13-2003, 02:04 PM
soldier6552's Avatar
So from what I understand, you must have a hurst factory option in order to be able to accomodate the LSS or JSS? If this is correct, how do I know if I have this option already? If I dont have this already I must instal a Pro 5.0 first?
-JOSH
Old 09-13-2003, 08:45 PM
pimpmaro's Avatar
http://www.afterthoughtsauto.com/lousshortstick.html
Here's the link to it. The dropdown menu has all the options.
Old 09-13-2003, 11:05 PM
I know the stick will increase noise, but does that mean just the clicks of shifting or being able to slightly hear the machinery >whirl< on occasion (in neutral or some downshifting)
I just want to check if noise is due to no rubber isolator and not part of tranny doing something wierd at this convienient time.
Old 09-14-2003, 06:34 AM
1BadAzzWS6's Avatar
Hardly any noise at all from my shfter. Just need to make sure all the bolts are tight. of course I don't think I'd be able to hear the noises over the exhaust and stereo anyway
Old 09-14-2003, 09:41 AM
WhitePheonix's Avatar
I liked it facing the dash, other wise I felt it sat to far back when I was in 2,4, and 6
