The Tick Performance Adjustable Clutch Master Cylinder Kits - SHIPPED!
#45
I haven't heard any one talk about the installation of this M/C over the stocker. Anything different? I have heard some mention of the wiring harness but not any kind of detail, also hear the pedal assy itself needs to come out?? Thanks.
#46
It goes in just like the stocker. I spent an hour taking the old one out and dropping the Tick master in.The harness just needs to be pushed out of the way while your guiding the master through the firewall
#47
i finally got mine in the mail friday. i havent had time to install it. how long do you think it would take for a newb to install this? is there anything that i should consider doing before,during, or after the install? thanks, james
#48
LS1TECH Sponsor
James - just check the direction/tip sheet that we sent with your order and you should be able to tackle it no problem. We charge 1 hour for installation and adjustment, so it shouldn't take a newb any more than 2 hours.
