Why Cartek's clutches RULE!
Call Cartek to be sure, I was told by Cartek not to shim the slave. HOWEVER, because it is what I am accusomed to I shimmed the flywheel the same amt that the machine shop took off when they re-surfaced it. Like I said give them a call they will be able to help you out no problem....
Jon
Jon
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Having been the car that R&D'd the clutch, I know how awesome it is! i can shift that bad boy with a stock trans, with no effort at WOT @7000rpm
I think they only make 1 kind now, just options as far as LS1/LS6 or LS2/LS7 flywheel, and I think they still have unsprung hubs like mine.
NICE! You'll love it...
Jon
#32
I came into this section b/c im having issues with clutch pressure at high speeds/RPMs, but after reading this thread might end up going with a new Cartek clutch setup and seems like I wont have to worry bout that anymore!
#35
Jon
#36
Nope, you shouldnt have any issues with the clutch, it holds and holds. A friend of mine(why I got my Cartek in the first place) put 30k on one, Dozens and Dozens and Dozens of 10 sec passes with N20, and even more N/A passes, and then sold it to another friend who put 15k or so more on it plus MANY track runs before it finally let go.
Jon
Jon
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#37
CARTEK Racing
As far as I know I was the only one to use the unsprung hub. I abuse that clutch more then any other of their customers, so they felt that I might as well have a slightly more aggressive version.
It seems like its a tiny been more "grabby" then the cars I have driven with the regular sprung hub. But since the pressure plate is the same in all cases, the pedal feel is the same. I did not notice any chatter from mine in comparison to the sprung hub either.
They are almost the same. Just mine is a little more aggressive on the engagement. But only fractionally. I think the choice was more for longevity... no springs in the hub, less stuff to wear out on those 7000rpm launches and shifts.
If you guys want to see how the clutch shifts, you can take a look at my you tube video.
There are some in car shots as well. Im shifting a STOCK T-56 with 65K miles at the time the vids were taken, with a CARTEK Clutch, CARTEK adjustable master cylinder, and stock slave cyl. Shifts are at 7000rpm at WOT, launches are mostly at 6200 to 6500rpm
http://www.youtube.com/watch?v=mTSA778AqtA
IM telling you.. Its the smoothest clutch Ive ever drive/raced
#38
lol great video man, love the song too.
