1999 Formula Hardtop project needs finishing SOLD
1999 Pontiac Firebird
  • 1999 Pontiac Firebird - 1999 Formula Hardtop project needs finishing SOLD - Used - VIN 2G2FV22G0X2228854 - 114,000 Miles - 8 cyl - 2WD - Manual - Coupe - Black - Chattahoochee, FL 32324, United States
1CAMWNDR is offline
    $1,234
  • Location Chattahoochee, FL, 32324, USA
  • Condition Used
  • VIN 2G2FV22G0X2228854
  • Mileage 114,000
  • Engine 8 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Coupe
  • Exterior Color Black
Selling my car that I ordered new in February 1999. It is VERY low option. The only options selected were the MN6 manual transmission and the Eagle GSC tires. It is a rare Hard Top and has a cloth interior and manual adjust seats.
Car has sat for about 4 years. Injury and finances are making me move on. All it needs is some time and effort and a couple odds and ends to get back running. New owner will need to decide about intended use and Auto vs rebuild the 6 speed.
General:
1999 Hard Top Formula Firebird. 114,000 miles on the chassis.
Originally Navy Blue Metallic, now John Deere Blitz Black Matte Black.
--included is more paint...should be enough to paint the whole car again.--
Taupe (Tan), manual adjust interior.
6-speed, factory replacement.
--Started grinding when shifting fast or Power Shifting into 2nd. Worked fine under regular driving. Probably needs new synchros.--
VFN Flat hood with pins.
--Will need to be cut to clear taller intake. '73 Shaker hood scoop included.--
Engine: 19,000 miles on engine.
LQ4 block filled to water pump ports with Hard Blok.
4.07" bore.
Compstar 4.100" crank.
Eagle 6.125" rods.
Weisco pistons.
LS9 head gaskets.
ARP head and main studs (Mains honed)
L92 heads, stock valves, stock chambers, port matched to intake.
@10.8:1 compression.
Victor Jr. EFI intake manifold port matched to heads.
Accufab 4150 4BBL throttle body.
Coil relocation to cowl with MSD 8.5mm wires.
Edelbrock fuel rails
42 lb injectors
Walbro 255 pump and Racetronix hotwire kit.
Spohn Solid motor mounts.
Alternator relocated to pass. cylinder head.
Trans:
Stock factory internals.
--Probably needs synchros...was grinding on power shifts.--
Pro 5.0 Power Tower shifter with shortened handle.
Tick Master Cylinder.
Monster Stage II clutch and flywheel.
Poly trans mount.
Denny's Nitrous Ready 3" steel driveshaft.
1350 U-joints.
Brakes:
stock replacement discs.
Hawk Pads.
No ABS.
Line Lock and proportioning valve.
--Line Lock buton on shifter ball. Power and Arm need to be rewired.--
Exhaust:
No EGR or AIR
Pacesetter Race 1 3/4" headers. Pacesetter coating. Surface rust.
Dual 3" electric cut-outs.
Custom 2 1/2" true dual exhaust built by me.
(2) Hooker Aerochamber mufflers at rear bumper.
Mild steel.
--**@2" extension needed at passenter collector...I don't know what happened there**--
Rearend:
Moser 9" housing and 31 spine axles.
Strange center section with 3.89 gears and Detroit Locker.
Rear LCA lowering brackets that I think were not installed correctly.
--**should probably be removed and reinstalled**--
Chassis:
Front bumper gutted, no hood latch.
No front sway bar.
Spohn Tubular Adj Upper Control Arms--**Need adjustments**--.
Strange Double Adjustable front shocks.
1" Drag rear sway bar.
BMR adjustable Rod/poly LCAs.
MWC Chassis mount adjustable torque arm.
Spohn weld in SFCs.
New BMR Adjustable panhard rod not installed.
Cut factory rear springs. ??TOO LOW??
--Factory WS6 rear springs for heater hose mod--.
Long wheel studs Front and Rear.
17x9.5 and 17x11 Torque Thrust II Classic wheels.
Front tires need replacing (Outer crown wear)
New Nitto 555 (NOT R) 315/35/17 rear tires.
Misc:
Interior trim present but semi removed. Was planning on making the car a weekend only street/strip toy but injury and finances changed that.
A/C works but I am sure needs maintenance.
Innovate LC1 and gauge in the A pillar.
Grant GT Classic steering wheel.
HPT 2.24 and laptop...I am not sure about transferring to new owner.
* S O L D *
Old 08-18-2018, 12:15 PM
1CAMWNDR's Avatar
Default More Pictures
Old 08-18-2018, 12:19 PM
1CAMWNDR's Avatar
Old 08-18-2018, 12:21 PM
1CAMWNDR's Avatar
Old 08-23-2018, 01:31 PM
1CAMWNDR's Avatar
Bump for Thursday afternoon.
Old 09-02-2018, 11:00 PM
1CAMWNDR's Avatar
Bump for Labor Day weekend.
Old 09-16-2018, 06:06 PM
1CAMWNDR's Avatar
Up again and a lower price!
Old 09-26-2018, 08:50 AM
1CAMWNDR's Avatar
Bump for nearing the end of Sept.
Old 10-09-2018, 12:27 PM
1CAMWNDR's Avatar
Currently hoping Hurricane Michael does not decide to hurl a tree at it....LMAO
TTT.
Old 10-12-2018, 05:50 PM
1500HP's Avatar
I’m interested PM me a phone number please
Old 10-13-2018, 05:17 PM
1CAMWNDR's Avatar
Just a small limb dropped next to the drivers door and laying on it.
Old 10-13-2018, 05:18 PM
1CAMWNDR's Avatar
PM sent. 👍🏻
Old 10-22-2018, 12:57 PM
1CAMWNDR's Avatar
Bump. Have a couple interested parties but nothing definite yet...
Old 10-29-2018, 01:26 PM
1CAMWNDR's Avatar
Bump. Still available as of 10/29/2018.
Old 11-13-2018, 11:01 AM
1CAMWNDR's Avatar
Back up approaching the middle of November.
Old 11-16-2018, 12:26 PM
eddyelder99's Avatar
Is the 9 inch and driveshaft installed?
Old 11-16-2018, 01:27 PM
1CAMWNDR's Avatar
Yes they are.
Old 11-18-2018, 02:36 PM
Can I see some pictures of underneath and the damage from the trees
Old 11-19-2018, 01:26 PM
1CAMWNDR's Avatar
Cannot get under the car since I cannot get in my garage to get a jack and stands. I will photo the door this evening. There is no damage from the limb that hit the ground and laid onto the car.
Old 11-19-2018, 04:58 PM
1CAMWNDR's Avatar
Pics of the driver's door. Other than needing a bath there is nothing wrong with it.
