Byron Sunday???
unloading bad lost the bog is unloading and spinning half way down the 60 best time was a 12.104 @118.31mph 60 was 2.042 and 1/8th was 7.940 @ 93.81 let me know when to take that rain check i will go with to 41 and play around with the set up.
I had a good time. Got in 4 runs. I had to shift at 5800rpm due to some valve floating issue i didnt have time to fix. But i was still good for 10.8 @124 with 1.5 60s. Ran 3 almost identical runs. And the best part was i didnt get kicked out for no cage.
Alex
Alex
8 SEC SLOPPY SHOT!!!
Yea andy went i think was able to get two runs in all day.I guess he had some bugs he needed to work out but kinda hard to do with two passes all day.I think he went 7.9?.
I mean 8.9? Sorry john you had that coming with your sig!!!
#33
You are not going to 60' that great with a 3.42. If you hook, you will most likely bog and possibly blow up the rear. You need a rear and 4.11s to get the most out of your set-up. Or if you are really serious, 4.56s with 28" tires.
#37
Track was hooking real good. Best time out of my 3 runs with the 2 step was 10.3 at 131mph with a 1.60 6oft. Have to get rid of the stock cats and change up the restrictive exhaust. Thanks to BlownC5 for letting me use his drag radials. He ran a 9.9 at 139mph and then ran a 10.4 with his girlfriend in the car.
