Help fight Illinois Gun Control with a 15 second phone call!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I saw this on Seat Stays Up...
You can call from anywhere in the U.S. Please help out the cause to keep your rights!![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Larry Suffredin and his cohorts on the Cook County Board are up to their old tricks again.
In order to justify passage of gun control ordinances designed to close all gun shops and ban and confiscate most guns owned by citizens of the county, the Cook County Board is conducting a telephone poll where callers can vote for or against the gun control ordinances.
Like everything else in Cook County, this poll is probably rigged. So, it's very important that you do the following:
1. Call 1-312-603-6400 and select Option #1 when prompted. At the next prompt, select Option #1 again. Then, when prompted to vote on the gun control ordinance, press #2.
2. You should also forward this alert on to all your gun owning friends and have them vote too.
3. You should also post this alert to any and all Internet bulletin boards or blogs to which you belong.
YOU DO NOT HAVE TO BE A RESIDENT OF COOK COUNTY TO VOTE!
Let's beat Suffredin at his own game! And, save our guns.
Thanks!
Thanks!
Just curious, which colleges? and where did you hear this?
