Transmission?
So either he will need to get a new pcm and harness (out of a 94+ car) to run the 4L60E or he will have to run a 700R4 to be a complete swap that will bolt in and work.
Unless he modifies the 93 harness using the v6 harness, and then he will only need a pcm from a 94+ car.
Although, The 4L60E that is in the V6 Car may NOT work b/c it's for a V6. Sometimes there are slight differences in the Transmissions.
James
