Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Tb porting
Old Aug 19, 2010 | 09:34 AM
ds98formula's Avatar
Default Tb porting
Any tb porters near Joliet IL? looking to get mine ported.
Old Aug 24, 2010 | 09:51 PM
SilverGhost's Avatar
Motorboater
I'm an hour or less away from Joliet and can take care of it..
Old Aug 24, 2010 | 10:09 PM
habeba86's Avatar
Sean(silverghost) did my tb porting and powder and it was fantastic!
Old Aug 24, 2010 | 10:18 PM
massconfusion's Avatar
you could always go at it with a dremel
Old Aug 24, 2010 | 10:58 PM
Motorboater
I've fixed quite a few that were ported with a dremel. Its not the right tool for the job even if the operator is pretty skilled with it. Too narrow of a sanding drum, too short/heavy/imbalanced and not enough torque. Every one I've seen was slightly out of round in the port work and left the metal slightly wavy where the ridge was removed. Sometimes you have to hit it with a smoother grit roll to see just how wavy it was left, but its there.
Old Aug 24, 2010 | 11:17 PM
4DoorRaceCar's Avatar
I am still learning a lot about mods and such...what does porting the TB consist of and what kind of gains does it produce?
Old Aug 25, 2010 | 01:26 AM
02TransAm/Batmobile's Avatar
Basically it smooths out the airflow into the intake. It's done my grinding away at some of the metal that restricts air flow in the throttle-body. It is definitely a worthwile mod and I've heard of an 8 horsepower gain. It depends on your setup.
Old Aug 25, 2010 | 11:13 AM
See I just don't get how you can have gains of close to 10 when the actual throttle body opening is still the same size, but I suppose with the right set up its not unimaginable.
Old Aug 25, 2010 | 12:33 PM
Again, it smooths out the airflow. Think of an aftermarket lid. The diameter is still no bigger at the MAF end but it's been proven to add horses because of the smoother airflow transition.
Old Aug 26, 2010 | 09:26 PM
Motorboater
Actually, the throttle body is NOT the same size as the intake throat from the factory, that's the problem. That ridge in front of the blade reduces the throttle body's bore by 5mm. Intake throat is 75mm, and from the factory the TB bore is only 70mm.
Largest gain is actually from removing that ridge. The shaping and material removal I do to the rest of the bowl gives gains also by further opening things up and improving the shape of the bowl, but getting that bore opened up to the full 75mm is the biggest thing.
Old Aug 27, 2010 | 03:43 PM
Bryceslu's Avatar
What do you charge for a stock LS1 porting?
Old Aug 29, 2010 | 03:41 PM
Motorboater
$65 for full port and bump stop mod. I also degrease the bore, blade, and IAC area and then media blast the exterior for a nice appearance.
Old Aug 29, 2010 | 08:17 PM
Bryceslu's Avatar
Where in Chicago are you located?
Old Aug 31, 2010 | 04:44 PM
Motorboater
Rolling Meadows. I'm real close to Woodfield Mall if that helps you reference it.
Old Sep 1, 2010 | 06:50 PM
InheritedZ28's Avatar
SilverGhost, What is your turn around time on a TB?
Old Sep 2, 2010 | 12:42 PM
Motorboater
Could do it in one day if need be. Usually its a few days, but one day turn around is certainly possible if you need it.
Old Sep 11, 2010 | 12:29 PM
Bryceslu's Avatar
Hey silverghost could you PM me your street address? I am up in schaumburg every now and then and am thinking about dropping off my TB to have you port it. or pm me your # either way.
Im kinda waitin on getting a winter car so I can have my TB off for a couple days.
Thanks
