Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
gears..
Old Sep 26, 2010 | 05:03 PM
ls1 ss 22's Avatar
Default gears..
So I bought my 98 ss camaro with 4.10s already installed in it. But the more I've drove it they keep getting more noisy. So I have got a new set and Just trying to find someone to install them. Can anyone help? And how much.. thanks you can text if that would be easier 7654803539
Old Sep 28, 2010 | 12:22 PM
GARAGE_BUILT_Z28's Avatar
just curious when you install the new set would you be willing in selling the old ones and for how much thanks..
Old Sep 28, 2010 | 03:30 PM
heymoej's Avatar
i also had this happen.......retorked the pinion nut & most of the noise went away,it must have loosened up.
check and see if they punched the threads right by the nut,there will be a punch mark so the nut does not back off.
just an idea.
Old Sep 28, 2010 | 05:32 PM
Ethan[ws6]'s Avatar
What kind of noise is it? You can usually tell the difference between a gear 'whine' or a bearing that is going bad, or improperly preloaded. If the pinion nut is not tight enough/too tight, the pinion bearing preload will not be set properly causing the bearing to (most likely) fail. If the wrong shims (wrong size(s)) are used, that will also have adverse effects on the bearings. The gear whine (if that is what you are hearing) is usually caused by backlash being too much or too little. You may not need to replace the gears just have someone look at it.
Old Sep 28, 2010 | 10:17 PM
ls1 ss 22's Avatar
It started make a loud grinding sound now. And I have to send the gears back to jegs the are warrantying them. Anyone be interested in putting the new gears in and if so pm me with a your info
Old Sep 29, 2010 | 09:17 AM
Ethan[ws6]'s Avatar
I would do it if I had the tools lol. I've done a few different rear ends successfully, but right now I just don't have the equipment to do it lol. Make sure you find someone that you know for a fact can do it right before you let them, my buddy just had his redone 3 times due to improper installation by shops that claimed they were the best haha.
Old Sep 29, 2010 | 06:31 PM
ls1 ss 22's Avatar
Was it a white z? Lol and I have all the tools you would need Just don't wanna mess anything up
Old Sep 29, 2010 | 10:18 PM
Ethan[ws6]'s Avatar
No it was a red ss haha. If you're sure you have the tools and would like me to do it PM me and we can talk more about it. I am currently living in Lima OH for school, but go to Indiana every weekend so maybe we can work something out. Just let me know.
