where are all the oklahoma guys?
#582
Nothing done yet other than a muffler delete and skip shift delete. I am however about to get a beater so the modding can began. First thing I'm going to do is long tubes and intake and should have that done here pretty soon. After that I am going to save for a cam and dyno tune (hoping to make 400whp) which should be done sometime in the summer. Only thing after that I have planned is adding nitrous later down the road (hoping to hit 500whp)
#585
I'm probably not going to do too much work to the suspension. I track the car a lot and it seems pretty good out of the box. I will be getting some hotchkis sway bars and that will probably be it suspension wise.
#591
The OKZCC (Oklahoma Z Car Club) host an open track day usually every month at the Oklahoma County Sheriff's Proving Grounds Track. It's a pretty relaxed track day (no tech needed, allowed to wear shorts/short sleeved shirts). The track is quite a bit larger than your typical auto-x course but not as large as Hallett. Best thing is it's only 35 bucks. Typically there are 4-5 groups that run 10 minute sessions. They run the sessions back to back with a break for lunch. It's a lot of track time for 35 bucks. If you are interested in taking your car out and having a little fun, I would definitely recommend it.
#597
