Suspension mods for rough roads?
https://ls1tech.com/forums/suspensio...l#post15157802
This is what I can think of:
- Go with Bilsteins shocks with stock springs.
- Make sure you're using rubber bushings in all bushing locations.
- Be sure your rubber bushings are in good shape.
- Remove the aluminum spacers from the bump stops in the rear if you have them.
- Run a narrower tire (245 or 255 all the way around, even narrower if you go with 16" wheel).
- if you're willing, go down a size to a 16" wheel, if you're running 17" or larger wheels, the extra sidewall will help absorb bumps.
- Check your tire pressure, keep it at not more than 30psi.
- Go with the most comfortable and quietest tire you can.
I'm crazy, I drive a LOWERED 2013 SS with 20's. I'm just waiting for a wheel failure one of these days.
