Ride is not smooth at all!
Okay I replaced my ball joints, i bought some kyb shocks non adjustable using stock springs. And my ride is still not very smooth. what do you think my ride needs for more smoother comfortable ride?
F-bodies will never have a really comfortable ride. They're solid rear axle performance cars...just not in the books for them to ride like a luxury sedan, or even a budget commuter car.
Shocks would be first thing on the list...I have KYBs on the daily, and while they're not bad, they're definitely not smooth-riding shocks.
so would you say that some higher end shocks would be a better fit for a smoother ride in it? because my wheel hops and I know I need new wheels and tires. but what would you recommend for like a really nice ride?
This is what I can think of:
- Go with bilsteins shocks.
- Make sure you're using rubber bushings in all bushing locations.
- Be sure your rubber bushings are in good shape.
- Remove the aluminum spacers from the bump stops in the rear if you have them.
- Run a narrower tire (245 or 255 all the way around, even narrower if you go with 16" wheel).
- if your willing, down size to a 16" wheel, if you're running 17" wheel, the extra sidewall will help absorb bumps.
- Check your tire pressure, keep it at not more than 30psi.
- Go with the most comfortable and quietest tire you can.
The following users liked this post:
Jayh (01-13-2022)
You are correct, performance will be harder/rougher in order to stay planted in corners. Honestly, adjustable shocks will provide better variety depending on how you want to drive. If your springs sag, or like mine are shorter, the effectiveness of a shock is diminished greatly. I have Strano/KYB AGX, and they ride rough as hell.
The OP could put decarbons back on. However, Bilsteins are a good quality shock that will accommodate ride quality as much as performance.
See below:
HD's are Bilstein's, so are SLP's. The front shocks are identical, the rears are so slightly different it's not worth nit-picking over. I can't really discern any difference really. Ride quality between them is not any different, and fwiw, ride quality has lots to do with other things too like springs, wheels, tires, etc. Unless you have both on the very same car the results are not accurate as the car differences will make more difference.
I'm sure he's serious. From his sig and profile, it looks like he's in to drag racing, so from his view the DeCarbons and QA1's are better.
Ride quality is subjective, especially so with a performance crowd (with a tilt towards drag racing). Most of the performance parts are aimed at drag racers here. Keeping the ride under control (other than when aiming dead straight), and off the bump stops isn't a priority for them.
bilstein with the stock spring is your best bet. I think when bilstein is paired with stock springs, it provides for a firmer ride but not necessarily harsher. bilstein with lowering spring will create a firm ride and noticeably harsher, although that depends a lot on what kind of lowering spring you use.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Im into drag racing too. You shouldnt say a crap shock is the best ride there is. QA1s are like one step above crappy. AFCO's are one of the better coilovers. Auto cross shocks you should be looking at Koni's. As for smooth ride? Dont know. Buy another car.
And bilsteins are not meant for lowering springs.
bilstein with the stock spring is your best bet. I think when bilstein is paired with stock springs, it provides for a firmer ride but not necessarily harsher. bilstein with lowering spring will create a firm ride and noticeably harsher, although that depends a lot on what kind of lowering spring you use. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I have this setup. I used to love highway cruising cause it rode so smooth even 80+. I have to change my setup cause the front end is getting floaty and too high cause Ive taken so much weight off the front end.
When I put konis on my car with no other suspension mods the car both rode and handled drastically better. It was more firm, but rode better because it was not jarring over bumps/dips feeling like the car was slamming like it did on the decarbons.
In your case KYB AGXs adjust rebound and compression with the same ****, so if you want more rebound you also get more compression, which will make the car noticeably more jarring - konis adjust rebound independently so you don't get that harsher ride.
![Icon Neutral](https://ls1tech.com/forums/images/smilies2/icon_neutral.gif)
