Southeast Michigan check in!!!
#44
Originally Posted by SLP LS1
The area can be really scetchy. A bunch of us usually travel in a group, so when we leave, not too many people there. Some nights, cops kick people out, some nights they don't. Most the time:Friday and Saturdays around 12:00am, you'll see some people over there.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#49
#53
Originally Posted by Ru2n00n3er
I'm working this semester up in Ann Arbor, I go to Purdue normally. My car is in a barn at home right now but it's probably getting Jet Hots and ORY, LS6 Intake, sub frames, and possibly a tune this summer. I'll be up here this fall to so I might look for some people to hang out with then.
Thanks, Bill
#54
Here are some pics of my new car being loaded up in TX for the trip back up here to Ann Arbor. The car should be arriving here in Ann Arbor around next Wednesday. Keep an eye out for it and say hello if you see me around.
List Of Mods:
2001 Z28, A4 w/TCS 3.23 w/ T-Tops
Light Neutral Interior
Glass Defroster
All Power Accessories
Monterey Maroon Metallic
Approx 11,300 miles placed on car, 8000 during 1st year of ownership
Never seen rain or snow
Wheel/Tires
Fikse FM5's 17x9.5 on all 4 corners
Goodyear GS-D3's
Interior/Exterior
Philips Ultinon 6k HID Bulbs
Philips Ballasts for HID system
Polished Aluminum Ballast boxes
PIAA 004x Driving Lights
PIAA 55w H3's, Ion Crystal
OEM SS Hood installed; still have original Z hood
OEM SS Spoiler installed; still have original Z spoiler
SLP Grille
SLP Floor Mats (new, still in package)
SLP Deck Mat
Hidden Wire Modification - Passenger Side
Z06 Gauge Cluster (checkered pattern); Trans Am Bezel
Autometer Trans Temp (carbon fiber), custom mounted in center console.
Custom Front/Rear Leather Seats (OEM Color Scheme, 2-tone)
Front Seat Heaters (2 heat settings); Carbon fiber material
All bolts under hood have been custom sanded and polished to mirror finish
Polished Coil Brackets
All MBA satin finish fluid caps
Madico Window Tint (lifetime warranty)
Jantzer Custom Powdercoated Maroon
- Lingenfelter Power Steering Pulley
- Power Steering Bracket
- Valve Covers
- Timing Chain Cover
- Alternator Brackets (not installed)
- Head Plate (Chevy Emblem)
- Thermostat Housing
Suspension/Braking
Performance Alignment
Black BMR Lower Control Arms
Black BMR Boxed Subframes, Welded
Black BMR 32mm Front Swaybar
Black BMR 21mm Rear Swaybar
Hotchkis Polished Alum STB
TA Perf 10 Bolt Cover w/ ARP Bolt Kit
Bilstein Tuned Suspension 1.5"
Custom Baer Track System - Front Calipers
- Black Powdercoating Caliper & Bracket; White Lettering
- Stainless Brake Lines
- 13" 2 Piece Front Rotors, Polished Alum Hat
- Drilled, Slotted and Zinc coated
- Baer Eradispeed rear rotors, Drilled, Slotted and Zinc coated
Engine/Induction
SLP Lid & QTP Motorsports Bellows & KN Filter
Katech Belt Tensioner & MBA Pulley
Absolute Speed 1x Heads Milled .030, 10.8:1 compression
Comp Chromemoly Pushrods (stock length)
Comp Titanium Retainers
Comp 918 (Blue Stripe Ver) Valve Springs
FAST LSX Manifold 78mm/All New Seals
FAST LSX TB 78mm (New Ver), Custom Polished - Mirror Finish
LS6 PCV System, LS6 Valve Covers w/new Seals
Thunder Racing 224.224 563/563 114lsa
Rollmaster Double Roller TC
Thunder LS6 Modified Oil Pump/New O-Ring
Nasty Performance Polished Fuel Rails and Fuel Pressure Gauge
Bassani Coated Mid-Length Headers & Y-Pipe w/Cats
Corsa Performancec Exhaust w/ Premium Tips
Meziere EWP (Satin Finish)
ASP Crank Pulley w/ARP Harmonic Balancer Bolt
Canton Oil Filter - reusable (change micron filter)
Canton Fuel Filter - reusable (change micron filter)
LS1 Edit Dyno Tuning (Speedwords in Lewisville)
Russel ProRace Braided line - Coolant Xover to Radiator
Russel ProRace Braided line - Coolant overflow
Russel ProRace Braided line - PCV to TB
NGK Iridium Plugs Gapped .050
GM Performance Wires (Red), Stock Heat Shields Polished
Gates Serpentine Belt
Lingenfelter/Samco Silicone Hoses (upper/lower radiator)
Ported and fully Polished MAF ends.
Hosetechnique MAF/TB Clamps - Fully Polished
Fluids
Redline 10w/30 Oil (changed 6x)
Redline 75w/90 gear oil (changed 2x)
Dexron 3 (changed 2x)
Redline Water Wetter - Fresh
Transmission
TransGo Shift Kit (2 shims)
Vigilante 2800 w/ 2.5str
B&M 19000 GVM Cooler (Front mounted)
Audio/Video
GM OEM Power Antenna
Alpine F752 5 Channel V12 Class T Series
Custom Amp Rack - allows clearance for t-tops
Alpine CVA-1005 In Dash Video
Alpine CHA-S634 6-Disc MP3 Changer
Alpine NVA-N751 Navigation Unit (Map for Southern Region)
Latest Navigation Map
JL 10w3 Mounted in JL StealthBox
MB Quart PSC-216Component (front)
MB Quart RKC-116 (rear)
DEI Permiter Alarm wired to OEM Alarm System
Optima RedTop Battery w/Warranty
All steering wheel controls maintained - PAC SWiX
Pictures
http://community.webshots.com/user/zr0260
List Of Mods:
Glass Defroster
Wheel/Tires
Goodyear GS-D3's
Interior/Exterior
SLP Grille
SLP Deck Mat
- Valve Covers
Suspension/Braking
Engine/Induction
Fluids
Transmission
Audio/Video
Pictures
#56
1-3 inches of snow overnight tonight... 3-5 tomorrow. High temps are about 10-15 degrees below normal for this time of year, and there's no relief in sight for the next ten days.
Just thought I'd brighten all of our days.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
#57
My company hires lots of people from Perdue. Any chance you are working on an engineering degree? What company are you working for?
Thanks, Bill
Thanks, Bill
#60
I'm a sophomore mechanical engineering major. I'm working for TTC right now, Toyota Technical Center, it's an awesome job. It's my first rotational term in the co-op program and by the time I graduate I'll have over a year of work experience, the co-op program is awesome. Where do you work?
Let me know what department you are in and I'll stop over and say hi sometime. What's your name?
Take Care,
Bill
