Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
What is needed for a TH 400 conversion??
Old Sep 8, 2005 | 12:37 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
There is also dean at DRC transmissions he has done these trannys to.He bulids alot of drag stuff and i know he builds trannys for some of the local sponsors.I never used him so i don't know how good his stuff really is.I think you would be very happy with a FLP.When you start running mid to low 10's then i would start to consider and tranny swap
Old Sep 8, 2005 | 12:48 PM
SgtB's Avatar
Thanks for the info Mike.
I will keep all this stuff in mind one I pull the tranny. I just havent had time to pull it yet. I am going to mess with some stuff today and see if I can figure out exactly what is causing it not to shift and go into limp mode.
I was told by a few trans guys that it is most likely not the converter...
Maybe a solenoid or a fluid leaking out of the breather( only thing is when i was under the car I did not see any fluid anywhere)
Old Sep 8, 2005 | 08:57 PM
tuff's Avatar
If it was a shift solenoid more than likely the ses light would be on.I think you just beat the hairs off that tranny. Check it out i would like to know what you tore up.
Old Sep 8, 2005 | 09:02 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I went 11.02-11.20 with my FLP level IV 4L60E for two years without any problems. I also sprayed that trans when the car was h/c/wet nitrous and it took a handful of passes no problem.
Old Sep 8, 2005 | 09:10 PM
tuff's Avatar
When you going out next?Ill be out sat night at GLD my 9.53 is going down!!!
Old Sep 9, 2005 | 08:00 AM
SgtB's Avatar
Well I still have an SES light from my cam swap so I wouldnt have noticed any new codes being thrown.
I also do not have a scanner and only having first gear I cant really drive teh car to autozone do have it scanned.
Old Sep 10, 2005 | 08:42 PM
SgtB's Avatar
Trans is smoked
I drove the car around the block to check stuff out and whn I checked the fluid it smelled burnt and started to get dark...
so I am going to have it rebuilt.
I just picked up a new fudddle converter to put in when when I put her back together...
Old Sep 10, 2005 | 10:09 PM
LS1Tech Co-Founder
I hope to race in the next 7-10 days Tuff, good luck.
Old Sep 11, 2005 | 10:27 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
let us know when you take it, i would like to see your car in action.
Old Sep 11, 2005 | 12:02 PM
LS1Tech Co-Founder
Hmmm.
How did Tuff do?
My wife's due date is 9.14.05 so this weekend could be bad...
Old Sep 11, 2005 | 01:54 PM
hope he has a vid.
Old Sep 12, 2005 | 07:27 AM
  #32
SgtB's Avatar
Yeah, I would like to see Mike's car run!!
Old Sep 12, 2005 | 05:43 PM
  #33
SgtB's Avatar
Hey anybody that lives close to me(Hanover Park) have a scanner?
My tranny guy wants me to scan my car before I pull the tranny.
I only have first gear so I can't make it to autozone and have them scan it.
Old Sep 12, 2005 | 07:03 PM
  #34
tuff's Avatar
Posted in the vid section.It my 9.47 pass
Old Sep 13, 2005 | 07:35 AM
  #35
SgtB's Avatar
Damn Mike,
That was awesome!! Nice pass!!
