ASR OFF, ABS INOP, BRAKE lights on!
Any one else have this problem after switching to welds with 28" rears and 25.4" fronts???
After searvhing I read that the dirrerent size tires cause this
Any way to fix this??
BTW, I did post this in the wheels and tires section.
i just wanted to see if anyone else has this problem
the rear tires are going through the same number of revolutions per second that the front ones are because of the height and its something you will have to deal with......
Retired Street Racer
Originally Posted by LiquidFire350
nothing you can do? not even ABS delete, computer tuning code deletes?
Originally Posted by ImportPatrolWS6
I have the same problem. Mine comes on at around 45mph, then will shut off once I turn the car off.
I think I may just pull the bulbs after my surgery.
btw...surgery is tomorrow so I will be out of comission for about 2 months
Don't cruise alot. Here and there sometimes. But it screws with the abs at times. So I am going to get rid of the abs, and I'll live with the lights for now.
Can you turn off ABS through a tune?
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by SgtB
What is is doing to your brakes??
Originally Posted by 4thGenCamaro
No, you can't turn it off through a tune. Just spend the $200 and get the SJM Linelock and ABS delete.
