Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Emissions Indiana
Old May 12, 2006 | 06:07 PM
96 LT-1's Avatar
Bad Seller Warning!
Default Emissions Indiana
What are the rules of emissions with exhaust in Indiana? You need cats correct? But do you need EGR and AIR? to pass? cant you get them deleted out in a tune so theres no codes thrown?
Old May 12, 2006 | 06:29 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
It's federal law for all 50 states to have the cats, egr, and AIR on your car if it came from the factory that way. Here in Central Indiana there isn't emissions testing, so you can follow the "what they don't know won't hurt them" policy.
Yes, you can have the codes tuned out. If you're near Central Indiana, check with "Black02SS" here on this board. He can tune out all the stuff for you.
Old May 12, 2006 | 10:41 PM
96 LT-1's Avatar
Bad Seller Warning!
So if i get the code out.... noone looks under my hood at the emissions place? Noone will no that the EGR and AIR is gone correct? and what if i were to leave the heat shields up for the cat do you think theyd notice that theres no cat there?
Old May 12, 2006 | 11:03 PM
RDeputy150's Avatar
No one will look under your hood from the "emissions place" because it doesn't exist.
Old May 12, 2006 | 11:26 PM
96 LT-1's Avatar
Bad Seller Warning!
huh??????
Old May 13, 2006 | 10:23 AM
Ru2n00n3er's Avatar
There is no actual emissions testing in Indiana. There are a few counties near Chicago that require it, but not the rest of the state.
Old May 13, 2006 | 12:33 PM
getsomebeyatch's Avatar
Around the chicago land we are required to have emmisions testing done ti get your plates. It is very simple to pass as long as you have a diagnostic port under you dash, they wont check anything but the gas cap and just check the comp. to see if there are thrown codes. If you are throwwing codes (i.e. ses light) have them fixed and deleted. I passed no cats long tubes and all just had 02 sims on, so no codes were thrown.
Old May 13, 2006 | 01:30 PM
96 LT-1's Avatar
Bad Seller Warning!
thanks beyatch that makes me feel much better now.... everything is go now !
Old May 13, 2006 | 02:21 PM
y2k_ta's Avatar
'Bird Director
So are you near Chicago then? That's the only place I know of that tests.
Old May 13, 2006 | 02:48 PM
96 LT-1's Avatar
Bad Seller Warning!
Yes i am NW Indiana Lake County
Old May 13, 2006 | 03:15 PM
y2k_ta's Avatar
'Bird Director
Good luck with your testing!
Old May 13, 2006 | 03:45 PM
96 LT-1's Avatar
Bad Seller Warning!
I dont have to do it for another 2 years... its just I didnt want to do my exhaust system then have to redo it to pass emissions.
