Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
PLease HELP!, Need help with these cams...
Old May 11, 2007 | 11:49 AM
litle88's Avatar
Default PLease HELP!, Need help with these cams...
Does anyone know where I can get my cams dr'd in the chicago land area?
They both are GM cams but the person who gave them to me forgot which one was which!!! There are no engravings on the side cause they are GM.
Any help would greatly be appreciated!!
thanks
Old May 11, 2007 | 12:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Don't they have serial numbers on there? I think there is a Cam DR. in Roselle somewhere.
Old May 11, 2007 | 12:29 PM
litle88's Avatar
the first cam has these numbers on the end of it, no engravings:
1721
S 17
1248
just like that on the end with like a square that looks like "checker board inside the square", or like a "crossword puzzle" like.which GM cams have right?
The second has no marks on the sides but has like a "blue marks" between the lobes and also in between the lobes are some very small numbers engraved in there. I believe they read:
10:516
@8002
just like that.
All help will be greatly appreciated!!!!!!!
Old May 11, 2007 | 02:42 PM
pro2low's Avatar
s17 is a cam from speed inc.
Old May 11, 2007 | 03:32 PM
litle88's Avatar
I took it to them and they couldn't identify them, I think I found a place and if so ill post it for others to know who offers these services
thanks pro for the reply!
Old May 14, 2007 | 01:11 PM
litle88's Avatar
I found a friendly machine shop that are helpful and courteous. They doctor'd my cam in one day!!! not trying to promote or endorse them just trying to get it out there for someone that might need machining or especially a cam doctor'd....
Fx Engines LLC
11121 W 189th Pl
Mokena, IL 60448
(708) 479-0900
ask for bob
Old May 14, 2007 | 01:17 PM
BADSZ28's Avatar
Can't you just take a micrometer to a cam? Measure the journals at no lift and full lift and subtract the 2 then multiply by 1.7? I would think that would get you lift of a cam. Correct me if I am wrong.
Old May 14, 2007 | 01:18 PM
BADSZ28's Avatar
That would be SI-7 not S17.
Old May 14, 2007 | 01:20 PM
litle88's Avatar
The cams are not in a motor, and you cant just measure the lobes with a micrometer, its a lil more complicated!
Old May 14, 2007 | 01:22 PM
litle88's Avatar
Not sure of the formula you mentioned MAtt, ill ask though when I pick'm up tommorrow, thanks though!!
Old May 14, 2007 | 01:25 PM
litle88's Avatar
The first one is a stock 01-02 ls1 cam:
1721
S 17
1248
the second turned out to be the LS1 HOTCAM!!!!
I know its a baby cam but its free!!!!!!
Old May 14, 2007 | 02:36 PM
Letsndy's Avatar
sell them and get a g5x3
Old May 14, 2007 | 04:27 PM
litle88's Avatar
How much can I get for either cam? anybody know?
