Another Hall's deal!!!
#4805
F-you Cobb i knew i was right yesterday at wings
Jacking
The C5 was the first car to use hydroformed frame rails. Hydroformed rails are quickly becoming a common platform for new cars, but not many shops are prepared to lift these vehicles. The C5 requires an adapter for regular jacks and lifts to fit the jacking points. Make your own adapters with a hockey puck (or two) with a 1 1/2" eye bolt screwed thru the center. Stick the eye bolt thru the slit in the jacking point, turn 90 degrees, place jack under adapter and jack away....if you can get the jack under the car. You may have to use ramps. The C5 is so low that most people make their own wooden ramps....rhino ramps are too steep.
Jacking
#4806
Jacking
Jacking
#4808
I'll PM you the details, as he is not a sponser on this board.
#4809
Lol I know. Is there any way I could do a cam a little more knarly without heads like Nate's doin but still makes power within the factory rev limits? I know that's probably too many stipulations but that's more like what I wanna do
#4813
Jacking
Jacking
#4814
go to great lengths for what?! the *****? because i've seen you bring around one girl, and you shortly there after quit talking to her because she wasn't your type. Sure she had tiny eyes,(and predator hair) but bad night vision or not she could have felt around for it... besides she had like wiener radar anyway, if there was a pecker to be had, she knew where to find it...
#4815
#4817
p.s. beast... i dont understand?
