Another Hall's deal!!!
#5642
Thanks for the compliments. I usually put an hour or two a night in it when I get home. I try and set a goal for one thing to complete each night, though waiting for parts changes that sometimes. My wife is a pretty understanding lady. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Drew,
The Vette bracket won't line up correctly. It's also higher I believe, but might still clear the hood. You would need a Vette crank pulley and tensioner if you went that route.
The LS1 Wizard bracket was 99 shipped. I can't get a crank pulley and stock bracket for that price!
Drew,
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#5643
Drew,
The LS1 Wizard bracket was 99 shipped. I can't get a crank pulley and stock bracket for that price!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Drew,
#5644
An LS1/RX7 won't clear the hood with a fast intake and throttle body, as it's too tall (have to use a Holley). The C5 will clear it. Your hood has a little bit of bulge right in that area, across the top of the motor. It's not a lot, but you've got at least 1-1.5" more hood clearance there than we do.
And, I'm sorry I missed your call, what'd you need?
#5646
LS1TECH Sponsor
Drew,
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#5649
Oh I was gonna ask you if you were keepin ur heads on the rx7 or if you were gettin different ones. I decided to go with 5.3 heads after talkin with Ben a little bit. Then I was gonna ask you which stage of 5.3 heads I should use. Shoot me a call tonight if you get a minute.
#5650
My heads are Vinci Racing stage 2.5s. I'm keeping them, though I doubt you'd want to pay for these if I were selling them. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I'd recommend Stage II heads from any of the good sponsors, with stainless valves, you can get great prices with spring and cam packages since you're starting at 0. I believe there is a local guy that does porting for a good price also, Joe can direct you his way. Regardless, I'll give you a call later.
#5651
LS1TECH Sponsor
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Zach,
If you're seriously thinking about doing 5.3 heads, check TSP (I'm sure ben has already told you) for their heads/cam packages. They have really nice prices on them! But if you wanna wait a year, I'll have some CNC'ed LS6 heads for sale.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#5652
That setup is good for about 800 at the wheels. At that point, the stock fuel lines get to be too restrictive. Once larger fuel lines are installed, its good to over 1,000 at the wheels.
#5653
As a point of reference, I'm going to be running basically the same setup as Ben (hey, it works for him). Mototron 60# injectors, dual Walbro 255 lph in tank pumps (Hobbs switch at 4# kick for second pump) though I've got a boost referenced Mallory FPR and -10 AN (yes, massive overkill) lines front to rear, with a -6 return line. The lines will feed something like 1600 RWHP.
#5654
60# Mototron injectors, Dual intank Walbro 255 lph pumps (2nd one is boost referenced off a HOBBS switch at 4#'s of boost) all on stock LT1 fuel lines.
#5658
hey guys i found my next corvette..i think the price is a little high for a 87' though
Item number: 330277669459
http://cgi.ebay.com/ebaymotors/Cars-...=p4506.c0.m245
#5660
there's a solid chance that i might be waiting and would buy ur ls6 heads. it sucks that i'm starting from scratch and have to buy the bolt ons first + corvette tax but it is what it is. again thank you guys for ur help, between you, ben, blake, nate, kenny ect (the list goes on and on) i'm starting to at least formulate a plan and some realistic goals
