Another Hall's deal!!!
#9165
I have been looking at some new pickups here lately. Trying to decide between a silverado and a f-150. I started looking underneath and i noticed how tiny the rear diff is on the GM. Has anybody hear anything about them not holding up? Also, whats up with only drum brakes on the rear on the GM. I know that there are 2 axles offered on the Ford. 1 is the little 8.8 ( same as on the mustang) and the 9.75 what i run now. I know that the 9.75 will hold up to extreme abuse. Since there is 2 axles offered on the ford, is there 2 also avavilable on the GM? I am pretty sure that i like the gm more then the ford, i just was worried about the axle and brakes. What do you think is going to happen with GM warranty if they file? Should i be worried about that?
#9169
#9170
My unbiased opinon is that the Chevy trucks ride a lot nicer than the Fords, but the Fords can usually take a little more abuse in the long run.
FWIW my parent's 2000 and 2001 Silverados both have trashed cab corners, and they were both very well maintained. They both have had tranny and transfer case problems also. Guy at work with an '03 Silverado has lost two transfer cases also.
#9179
Nick,
We'll have to build a support bracket for that fo' sho.
On a positive note I figured out how to save you ~90 dollars on the oil feed setup. Woohoo!
Let me know when you get the pan and stuff ready and we'll get some more work done on the car. Do you have access to a MIG to start tacking the hot side?
Oh and Drew, you'll appreciate this. I apparently have multiple gouges in my cornea. Guess that explains why my eye has been bothering me. RediMed gave me numbing agents for my eye. I now look even more special ed. then normal, but it doesn't bother me now.
#9180
Sold when the gas skyrocketed but we used to have a 2002 silverado short bed side step Z71, and I loved that truck, ride, turning radius, power, and 4 wheel always pulled us out. A lot of those trucks had an issue with the marker lights in front going out prematurely. and I think we had to tighten the steering wheel hub but that was it. Brakes were easy to change. I love a 5.3 ltr motor. Maybe ford does this too ,but the skin of the bed was plastic to save weight. we stil lonly got maybe 17-19mpg.
