Another Hall's deal!!!
#9801
The guys in the shop were a little bored yesterday, and got a kick out of Nates animation, so they figured a Brad and Joe conversation would be good to add.
http://www.xtranormal.com/watch?e=20090421205458398
#9803
I think Drew and I solved the clutch mystery.
We pulled the bellhousing last night and when I did, I noticed there were no dowels on the block to align the bellhousing. Apparently, the guy he bought the motor from removed them (kinda weird).
When we originally mated the tranny/engine, we had the transmission and bellhousing together, so the input shaft aligned everything. When Drew was pulling the car into storage last year, he bumped a lip on his barn on the underside of the car, and that's when the slave failed. As best we can tell, because of the lack of dowels, the transmission shifted slightly when it was bumped, which caused the slave to fail.
Jump to this spring, we pulled the trans off the bellhousing, rebuilt it, replaced the slave and reinstalled it to the bellhousing (which was still misaligned). Bleed clutch and the new slave fails just like the old one (when we pulled the slave out, it was jammed all the way out. Even with no fluid we had to use a vise to get it to actuate freely). I have a spare motor with dowels on it that I pulled off, and we will put them on Drew's motor, get the alignment taken care of and reinstall everything (with a new slave, again) and I think all will be fine. The pressure plate, clutch disc and flywheel all looked fine.
The joys of wrenching...
#9807
This is mostly for Blake and Nick, but OMG... everyone should watch it...
http://www.youtube.com/watch?v=zxsY4...layer_embedded
#9808
I'm just too cheap to pay others for labor. Thus I have to figure out what I'm doing (or at least do a good job pretending).
#9809
#9811
I decided to pull the trigger on a 8.8" IRS diff swap for the 7, does anyone know someone with a totaled Thunderbird or Lincoln MK-VIII? I niid the diff housing and cover out of it
#9812
#9813
#9814
[QUOTE=digitalsolo;11462855]**** a wrench, get a MityVac. Doing Azar's clutch tonight with a MityVac. Manual bleeding sucks!
Hell, come over and do mine to, that way I don't have to buy one
#9816
#9817
So my wife showed me this. I thought it was funny as hell!
http://new.music.yahoo.com/eminem/vi...you--208585920
#9819
I saw this and I just had to post this, because I know some of you guys would get a kick out of this Camaro!
https://ls1tech.com/forums/appearanc...-car-show.html
