White RA TA at Scottys in Indy
There was a White LS1 Ram Air TA outside Scottys Brewhouse in Indy. It had a LS1tech.com decal on the back window.
I am interested in the way you had the bottle in the back, and wanted more info on the mount (or was it just laying there?).
Thanks.
Thanks.
Yep it was me.
It was mounted on a seat delete. Not just laying there .
Not sure where the seat deletes were made because I got them from a friend, and they came with his car.
They look like they would be easy to make. Let me know if you want to take a look at them close up or taken out.
Heres a pic of the bottle mount.
I definately want to check it out, I was going to mount it on the rear hump with a nitrous outlet setup. I think your setup would be a bit less "in your face" and would work nice.
My back seats never got used so I didn't care about taking them out.
It does sit lower than the hump so it is less in your face. Not to many options for mounting a 15# bottle. Your choices are where I have it, on top the gas tank, trunk or spare area that is about it.
Plus if you mount it in the trunk/spare area or gas tank you have to have a remote gauge to monitor pressure and will most likely need a remote opener.
I wouldn't need these things because I just purge alot but someone who does use it might not want to spend the extra money for all the extras.
