Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
It's Alive!!!!
Old Sep 17, 2008 | 01:45 PM
Tuner@Straightline's Avatar
Default It's Alive!!!!
After sitting in my garage collecting dust for about two in a half years, I'm finally getting my 36,XXX mile 2002 Z28 A4 up and running. Nick (owner of Straightline Performance), Chris Bradley, Brandon Hammond, myself, and a few others have been putting in long hours after work in order to get this together.
Here's a little history on my long over due project. I purchased the car in 2004 from a friend how was going to trade it in on a 2004 CTS in October of 2003. I had 16,XXX miles on it at the time. This was going to be my daily driver because I had a 1997 Trans Am project going on at the time. I took the car to US 41 where it ran a 13.02 @ 113.8mph with only a SLP air lid. On our Mustang Dyno it put down 312rwhp with a mild tune and SLP lid.
As much of us are, we're never satisfied. So I picked up some used Hooker SC Long Tubes, a Yank SS 4000 converter, and a LG G5x3 cam. Installed all that good stuff, made 393rwhp on our dyno, ran a 11.7 @ 116mph at US 41 with a 1.55 60'. On my second pass, it pulled a 1.50 60', but only ran a 12.4. Something was definitely wrong. 6 of the 16 valves springs had shattered the outer spring. Time for a rebuild. . . .
My first goal was to convert the car to a manual since I really missed banging gears in my 2003 350Z. So I traded everything needed to do this with somebody looking to do a swap. My next goal was to use twin GT35R turbos on stock displacement motor. So I dropped my block off at our engine builder at the time, who had it for over a year without ever assembling the anything. Then within a week it was done. I had it sit for a while, while trying to save up for everything else that I needed, when Alex (Sprayed01) asked me if I would consider selling him the motor. I got back to him and worked out a trade where I got his LS6 short block out of the deal.
My first inclination was to just put a cam in the car and call it done, then sell the car. Well, being in the performance business, it's easy to come across deals. Soon one deal led to another and so forth. . . .
Here's how the car stands currently. It's a 347cui LS6 with forged and coated pistons, H-beam rods, Rollmaster Dual Roller timing set, and Mellin HO oil pump from P.E.R. in Plainfield (our current engine builder, thanks Randy!). TEA Stage 2 LS6 heads milled to 59cc with upgraded springs (heads flowed 323 IN/262 EX @ .600). Cam selection is a 24x/24x, .620/.622 @112+2 by Comp Cams, I'll give the full specs based on the results. Cooling is done through the stock radiator and Meizer electric street water pump. Intake starts with a FASTTOYS.NET lid, through a 2002 Z06 MAF on it's way to a FAST92 Intake and throttle body. Fueling is done by a Racetronix hotwire kit and fuel pump, and Lucas/Delphi 42lb/hr squirters. Exhaust is handled by Kooks 1 7/8" Race long tubes, Kooks Off road pipe, and Corsa cat back (Thanks Gus!). The trans is an RPM Level 4 T56 with some upgrades, and an LS7 clutch set up. For now it's going to be on stock wheels and suspension. I hope to get that changed in the spring.
The installation and conversion went really smooth for the most part. It's really nice to have all the major pieces for such a project. On a side note, my original motor that the first engine builder built, was supposed to go on the engine dyno. I had given them all the accessories and bolts, everything neatly labeled in little plastic bags. When I got everything back, I got the long block, the accessories, and what I thought was all the bolts. So I spent most of the time picking through a bucket of misc. bolts trying to find matching ones for whatever was needed. That and the fact that around 12 am, I became absent minded due to lack of sleep, I would misplace something that we needed (most of the time it wound up on the lift or in the car).
I'm currently waiting for one part from BMR, and I'll be able to get it on the dyno. I took some pics I'll be sharing with you in this post from the other night, and I'll update it when I get more taken.
Last night we fired it up for the first time, and OMG. . . The sound. . .The best I could describe it is that it's like angry demons trying to escape to eat small children, then spit out their bones like bullets causing more havoc. I'll be sure to get some video up soon.
Attached Thumbnails It's Alive!!!!-2008_09_17-022.jpg   It's Alive!!!!-2008_09_17-023.jpg   It's Alive!!!!-2008_09_17-024.jpg   It's Alive!!!!-2008_09_17-025.jpg   It's Alive!!!!-2008_09_17-027.jpg
Old Sep 17, 2008 | 02:16 PM
98blueSScamaro's Avatar
i want to see how the heads work befor i get mine
Old Sep 17, 2008 | 02:53 PM
99DROPTOPZ's Avatar
Wicked It takes a lot of money, knowledge, and time to build these cars up right and it looks like you did an awesome job on this project when its all said and done its well worth it in the end. Nice story and good luck on those track times.
Old Sep 17, 2008 | 03:13 PM
scramblerman's Avatar
happy to see your car almost done Mike. I remember talking you you about those heads, and glad you went with them. They flow really good. Make sure you post up a vid of the dyno pull.
Old Sep 17, 2008 | 04:01 PM
BADSZ28's Avatar
I was starting to think your car did not exist. Glad to hear she is running. Can't wait to see dyno/track results.
Old Sep 17, 2008 | 05:07 PM
litle88's Avatar
Remember MIKE! (Cue the Darth Vader voice)
No more showing off in the RAIN with WOMEN as passengers!
Besides that congrats and hope to see you and your "DEMONS" tomorrow!
I need the idle to around 8hundered pleeeeeeeasse!
Old Sep 17, 2008 | 05:27 PM
JD1969's Avatar
Nice to see you have your car running again Mike.
Old Sep 17, 2008 | 06:12 PM
NHRAFORMULA00's Avatar
Sounds nice Mike! What is the static compression? Let me know when your ready to take it out to the track!!!
Old Sep 18, 2008 | 11:10 AM
SSSSSSHHH! Otherwise I'm changing the firing order on your car!
It's an 11.5:1 SCR. I don't think I'll be getting to the track until I have a rear end for it next season. Who knows, I'm easily convinceable, so that might change.
Old Sep 18, 2008 | 01:22 PM
SchultzLT1's Avatar
Hahaha I vote for 1-3-5-7-8-6-4-2
Justttt to see what happens
Old Sep 18, 2008 | 07:23 PM
02sleeperz28's Avatar
Hey Mike can I have your motor pleaseee and how about when I done with my car you give me 4 and the move thats sounds fair
Old Sep 18, 2008 | 08:41 PM
LT1Formula007's Avatar
congrats man!
Should run great!
Old Oct 9, 2008 | 06:57 PM
cpd004's Avatar
Since I really really need a motor and you like selling them....how about a trade for my Lingenfelter P.O.S.?
Anyway....congrats and tell the rest of the guys there I said hey!
Sounds very similar to my combo except I bet you have better oil pressure.
Old Oct 9, 2008 | 07:04 PM
LS1-NAVY's Avatar
congrats man
Old Oct 9, 2008 | 07:27 PM
Pockitz's Avatar
HOLY ****!!!! i dont believe it! its actually gonna be alive!!!? im glad you changed your mind and decided to keep it mike, its your pirde and joy and its really cool to see it back in action, i gots dibs on a shotgun seat for a ride, but Nick is driving!!!
